Hopefully the next iPhone and iPad will fully support 160MHz. Those speeds you are getting are really good though.
Can you log into router via browser and Screen capture the Wireless log, this will show us all connections and data rates etc.
I have done some investigation and if you switch it to 160mhz only instead of 20/40/80/160 my surface 4 then shows 2400/2400 so it allows dual band. Previously even with 20/40/80/160 selected its wont double up its has to be only 160mhz only. I have done a speed test and its gets nearly 900mbps on wifi so problem solved. just a shame not many wireless cards inc apple MacBook Pro are 160mhz enabled. useful to know for anyone else having similar problems on the FTTP 900 and didn’t notice this at all when on the 500/75 package.
I was pretty sure that your issue was that devices were conneting via 80MHz when you had it set up as 20/40/80/160. Baffling how modern PC/mobile devices are still not 160MHz compliant.
Thanks.. We only have 1 XT8 and use the 5GHZ-2 for mainly high speed devices like the MacBook pro, iPhone etc. I have uploaded the settings for the 5GHZ-2. :)
Can you try setting 160MHz rather than 20/40/80/160MHz? That way you will know for certain if your device can/is connecting to 160MHz.
The max speed over WiFi I have received on my S23 Ultra is around 650-700mbps. There is always some loss/overhead over WiFi, and yes 80MHz is the max on 5GHZ-1. 160MHz is reserved for the 5GHZ-2.
From what I understand, if you use wired backhaul you may be able to use 5GHz-2 for WiFi. I have not tried this at all.
I suppose it could also require the APP to be updated as well as ASUSWRT, ?
I think this is more likely something that the APP team need to sort out.
I have flashed to this release. There is still no option to set 5GHz-2 password via the app. I set it up via the web GUI
ASUS ZenWiFi AX (XT8) Firmware version 3.0.0.4.388.23285
-Resolved the issue where the USB path is not displayed on the Media Server page in the AiMesh node
-Resolved the Download Master login issue. Please click the update link in the USB Application to update it.Security updates:
-Fixed the vulnerability in the logmessage function. Thanks to Swing and Wang Duo from Chaitin Security Research Lab C0ss4ck from Bytedance Wuheng Lab, Feixincheng from X1cT34m.ZenWIFI XT8 of HW Ver: 1.0 – https://dlcdnets.asus.com/pub/ASUS/wireless/ZenWiFi_XT8/FW_ZENWIFI_XT8_300438823285.zip?model=ASUS%20ZenWiFi%20AX%20(XT8)
ZenWIFI XT8 of HW Ver: 2.0 – https://dlcdnets.asus.com/pub/ASUS/wireless/ZenWiFi_XT8/FW_ZENWIFI_XT8_V2_300438823285.zip?model=ASUS%20ZenWiFi%20AX%20(XT8)
Looks like ASUS is not only being complacent with their Router/Modem FW, but even worse with Motherboard bios and support. ASUS really need to pull their socks up or will start to suffer:
Content creators on YouTube are ripping into ASUS now, quite rightly too.
I have been testing the latest GNuton’s Asus Merlin beta for nearly 10 days (388.2-gnuton0_beta1)
https://github.com/gnuton/asuswrt-merlin.ng/releases
Dirty flashed it over 22525 and it has been working flawlessly for my use case.
@UK Sentinel, will you be able able to ask ASUS if this is a new ‘feature’ or a known bug? Or is it just me doing things wrong? Thanks
Ok, so had to chase ASUS on this, but ASUS have confirmed that during setup with the app there was no option to set password for 5GHz-2.
This issue indeed can be reproduced, related engineers now working on a solution
Thanks for getting confirmation from Asus.
I agree that 22525 was much more stable than 23012. Found one of the 3 nodes lose show weak connection quality. Simply clicking ‘reboot node’ fixed it. Not sure when that happened or why. Might give it some more time to see if it happens again or may just revert to 22525.
not posted yet but i still downloaded and also did a dirty install. so far no obvious bugs have come up yet. Will observe for now.
I also dirty flashed initially and it all seemed ok too. I then decided to do a full factory reset to see if my issue with 160MHz backhaul was resolved.
Possible bug in the V1 firmware. After setting up with full pin and WPS reset, the 5GHz-2 network is setup as open. During setup with the app there was no option to set password for 5GHz-2. Seems like the 160MHz ‘bug’ is still also present for me.
