BT Infinity Disconnects
› UKTH forums › 📡 Broadband Tech & ISP’s › BT › BT Infinity Disconnects
Viewing 15 posts - 46 through 60 (of 103 total)
  • #3365
    • Replies 8,708
    Did this happen more than once ?
    #3366
    Bully
    • Replies 386
    Did what happen more than once ?
    #3367
    • Replies 8,708
    Did you run the test only once or multiple times with similar results, I ask as the results you pasted shows packet loss, which is not good .
    #3369
    Bully
    • Replies 386
    No I ran it a few times, same ping and only packet loss once.  My up stream is now on fast path –
    DS Actual Rate          : 48996000 bps   US Actual Rate       : 10876000 bps
    DS Attainable Rate      : 60662056 bps   US Attainable Rate   : 10809939 bps
    DS Interleave Depth     :      757       US Interleave Depth  :        1
    NE Current Attenuation  :       20 dB    Cur SNR Margin       :        3  dB
    DS actual PSD           :     6. 4 dB    US actual PSD        :    15. 0  dB
    NE CRC Count            :       13       FE CRC Count         :     1382
    NE ES Count             :        4       FE  ES Count         :     1166
    Xdsl Reset Times        :        0       Xdsl Link  Times     :        3
    #3371
    • Replies 8,708
    Good news packet loss only once, you SNR is still 3, and Fastpath on Upstream ;-)
    Would be good to give it a few more days, just to see if any other improvements happen ?
    #3438
    Bully
    • Replies 386
    Couple of weeks since –
    DS Attainable Rate      : 59419048 bps   US Attainable Rate   : 10638705 bps
    NE Current Attenuation  :       20 dB    Cur SNR Margin       :        2  dB
    DS actual PSD           :     6. 4 dB    US actual PSD        :    14. 7  dB
    NE CRC Count            :     1534       FE CRC Count         :     1996
    NE ES Count             :      187       FE  ES Count         :     1767
    #3443
    • Replies 8,708
    So no real changes then over the last week or so, you still have improvements on the original download speed, but higher Interleaving.
    If you are feeling brave, try increasing SNR to say 6 / 9 and see if you can improve on the interleaving value.
    Or maybe see if you can get G.fast, as this is really your only other option for increasing throughput speeds etc.
    http://www.dslchecker.bt.com/
    Screen dump results if you would or PM me them via the contact form on the web site
    #3446
    Bully
    • Replies 386
    • Replies 8,708
    Shame, looks like you are more then 300Metres from the cabinet, hence no G.fast option.
    You do have the option for FTTP-On-Demand which means basically you have Fibre to Home and is expensive , shame really ;-)
    Maybe worth call to ISP ? just to find out pricing ?
    Openreach Place Stop Sell on FTTPoD Orders After Spike in Demand
    #3581
    Bully
    • Replies 386
    My line has gone haywire – these are the stats after I changed from Snr -50 to -25, at -50 my interleave was at 1755.
    DS Actual Rate          : 41422000 bps   US Actual Rate       :  9909000 bps
    DS Attainable Rate      : 52050632 bps   US Attainable Rate   :  9939795 bps
    DS Interleave Depth     :     1512       US Interleave Depth  :        1
    DS actual PSD           :     6. 5 dB    US actual PSD        :    13. 1  dB
    NE CRC Count            :        1       FE CRC Count         :     2219
    NE ES Count             :        1       FE  ES Count         :     1987
    Xdsl Reset Times        :        0       Xdsl Link  Times     :       15
    #3584
    • Replies 8,708
    What does the “vdsl status more”  show ?
    Your DS Interleave Depth    was      757  – Remind me why this changed ?
    #3585
    Bully
    • Replies 386
    What does the “vdsl status more” show ? Your DS Interleave Depth was 757 – Remind me why this changed ?
    Not sure why it changed.
    Status more stats –
    > vdsl status more
    Bitswap      :      0               1
    LOS          :     20               0
    LOM          :      2               0
    FECS         :   5718            27985 (seconds)
    ES           :      1            1987 (seconds)
    SES          :      0              10 (seconds)
    LOSS         :      0               0 (seconds)
    UAS          :     33            24910 (seconds)
    CRC          :      2            2219
    INP          :      0              35 (symbols)
    InterleaveDelay :      0            1400 (1/100 ms)
    NFEC         :    255              65
    LSYMB        :   2899            13793
    INTLVBLOCK   :    255              65
    #3587
    • Replies 8,708
    Understood, Try to bring the modem back to normal settings for SNR
    vdsl snr 50 (see if his work as reducing the SNR has proven troublesome for yourself)
    BTW – did Interleaving increase for no reason, or had it been 1755 for  while ?
    #3599
    Bully
    • Replies 386
    I think it increased due to errors, Saturday I had on the DS – 130 NE CRC count and Sunday it went upto 60928, with one disconnect.
    I have reverted back to default snr value, these are the stats –
    > vdsl status
    DS Actual Rate          : 37020000 bps   US Actual Rate       : 10719000 bps
    DS Attainable Rate      : 43781096 bps   US Attainable Rate   : 10755936 bps
    DS Interleave Depth     :     1306       US Interleave Depth  :        1
    NE Current Attenuation  :       20 dB    Cur SNR Margin       :        6  dB
    NE CRC Count            :      638       FE CRC Count         :     2241
    NE ES Count             :       67       FE  ES Count         :     2009
    Xdsl Reset Times        :        0       Xdsl Link  Times     :       18
    #3603
    • Replies 8,708
    DS – 130 NE ?
    So SNR is back to 6dB and your interleaving has dropped slightly but your ‘DS Actual Rate’ has dropped by 4Mb
    Does the level of interleaving cause you issues ?
    As far as I recall, ECI Cabinets support Fastpath both ways, so only real reason why you are not achieving Fastpath is probably due to the amount of errors you are getting ?
    I am now wondering if your errors are at certain times of the day/evening (not sure if we have covered this on my old forum) ?
