Up and running now. Speedtest shows slightly faster than what I ordered. This is over wireless powerline. So far very impressed.
I drilled a hole through the metal door frame in the living room. Hyperoptic came and installed the socket and connected the router (ZTE H298A). Activation is on Monday
I had to cancel the order. There are no wall sockets available in my hallway. They refused to drill a hole to the nearest socket in a room as they only run cabling on the surface indoors.
The wiring is already done up to the front door. Once you order they need to drill a hole through the door frame. Then run cat 5 cable to the nearest power outlet.
I was going to be given the Tilgin HG2381. Unfortunately the lady engineer would not be able to run the cable to my living room. Need to drill a hole through the wall
. Stuck with the DSL AC88U
Thanks for that, looks like the other one is Tilgin HG2381. Never heard of either of them
. Enjoy your dinner…..You need to login in order to vote
January 18, 2020 at 9:32 pm in reply to: ASUS – DSL-AC88U / DSL-AC3100 Firmwares (beta's) etc. Looks like a new Beta Release for the DSL-AC88U is available, this version has Telnet enabled and improved 2.4GHz wifi (I believe). DSL-AC88U_v9.10.06_build581_debug.w.zip https://www.asuswebstorage.com/navigate/s/604D61534F2541D1B3CE1CC031A697E4Y UK Sentinel In a completely... #5799My contract with TalkTalk runs out in a month or so. Hyperoptic is available in my building. Never used them before but decided to take the plunge on their 150Mb package. Hope it is the right decision. At least I will not have to deal with this router for a while if things go well.
January 12, 2020 at 10:20 am in reply to: ASUS – DSL-AC88U / DSL-AC3100 Firmwares (beta's) etc. Looks like a new Beta Release for the DSL-AC88U is available, this version has Telnet enabled and improved 2.4GHz wifi (I believe). DSL-AC88U_v9.10.06_build581_debug.w.zip https://www.asuswebstorage.com/navigate/s/604D61534F2541D1B3CE1CC031A697E4Y UK Sentinel In a completely... #5733@UK-Sentinel: switched with a relay, starting on g.fast and after a minute or so switching to DSL. for G.fast: Microsemi MSC Le87281 and rest: Broadcom BCM6303
Is the BCM6303 an old chipset? How does it compare to the one found on the DSL-AC88U?
January 12, 2020 at 9:37 am in reply to: ASUS – DSL-AC88U / DSL-AC3100 Firmwares (beta's) etc. Looks like a new Beta Release for the DSL-AC88U is available, this version has Telnet enabled and improved 2.4GHz wifi (I believe). DSL-AC88U_v9.10.06_build581_debug.w.zip https://www.asuswebstorage.com/navigate/s/604D61534F2541D1B3CE1CC031A697E4Y UK Sentinel In a completely... #5730If I buy a 7582 from eBay (sellers are from Germany and Austria), will the UI be in English?
Also will you still receive firmware updates as normal?
January 10, 2020 at 12:27 am in reply to: ASUS – DSL-AC88U / DSL-AC3100 Firmwares (beta's) etc. Looks like a new Beta Release for the DSL-AC88U is available, this version has Telnet enabled and improved 2.4GHz wifi (I believe). DSL-AC88U_v9.10.06_build581_debug.w.zip https://www.asuswebstorage.com/navigate/s/604D61534F2541D1B3CE1CC031A697E4Y UK Sentinel In a completely... #5703The 7590 looks good. I read somewhere g.fast is on the 7582 and 7583, cannot find one on Amazon for UK use. I use the google WiFi Mesh for reaching far ends of the house. Works really well for me.
January 9, 2020 at 10:30 pm in reply to: ASUS – DSL-AC88U / DSL-AC3100 Firmwares (beta's) etc. Looks like a new Beta Release for the DSL-AC88U is available, this version has Telnet enabled and improved 2.4GHz wifi (I believe). DSL-AC88U_v9.10.06_build581_debug.w.zip https://www.asuswebstorage.com/navigate/s/604D61534F2541D1B3CE1CC031A697E4Y UK Sentinel In a completely... #5699Routers are completely different story, as for routers there is custom fw where are lot of bugs are solved. Merlin guide Asus with future releases and even help them with official releases. Not to mention that in some cases he tested if not even testing now pre release builds. (just info I found online). I use custom fw on my new rt-ax88u and is rock solid, so where I will never look on asus all in one device(modem-router) there is a definitely option for router only from asus.
I am aware of the support provided by Merlin with Asus routers, but I cannot give money to a company that treats customers this way. After all the problems with the AC68U, I had hoped that they will have learnt from their mistakes.
Anyone know if there is a Fritzbox that supports g.fast for UK?
January 9, 2020 at 7:13 pm in reply to: ASUS – DSL-AC88U / DSL-AC3100 Firmwares (beta's) etc. Looks like a new Beta Release for the DSL-AC88U is available, this version has Telnet enabled and improved 2.4GHz wifi (I believe). DSL-AC88U_v9.10.06_build581_debug.w.zip https://www.asuswebstorage.com/navigate/s/604D61534F2541D1B3CE1CC031A697E4Y UK Sentinel In a completely... #5695If mine was still under warranty I would definitely return this now. Asus have been absolutely disgraceful with the lack of support on this product. I for one will not be buying any more modem/router or router only devices from them. Why would I buy anything from them when they treat customers like this?
January 5, 2020 at 6:18 pm in reply to: Latest DSL-AC68U Firmware – Version 3.0.0.4.384_81981 Latest DSL-AC68U Firmware – Version 3.0.0.4.384_81981 (2019/12/31) ASUS DSL-AC68U Firmware version 3.0.0.4.384_81981 (This product supports both Annex A and Annex B) DSL: – Added ADSL profile for Lebanon ISP Ogero.... #5663Happy new year UK Sentinel.
It is great Asus are still supporting this model. I had one before and the features on it were amazing. Only reason to get rid of it was that it was not good for my longish line.
Shame Asus does not show any love for the newer DSL-AC88U.
October 5, 2019 at 7:34 pm in reply to: PureVPN setup on DS- AC88U Does anyone have PureVPN setup on the the DSL-AC88U? I am on debug build591 and having difficulties setting this up. Any help? #4704Yes I am using the modem on the DSL-AC88U with wireless turned off. I have Google Mesh handling the Wi-Fi.
October 5, 2019 at 12:09 pm in reply to: PureVPN setup on DS- AC88U Does anyone have PureVPN setup on the the DSL-AC88U? I am on debug build591 and having difficulties setting this up. Any help? #4701It’s using the OpenVPN method and the following guide:
https://privatevpn.com/support/getting-started/routers/asus-rt-models/openvpn
