Viewing 15 posts - 1,246 through 1,260 (of 1,439 total)
  • #11320
    Avatarn13ldo
    • Replies 31
    Decided to splash out on a RT-AX88U (connected to HG612 3B). Superb performance from the router but still to try out Wifi6 (phone and laptop support natively).
    The RT-AC88U I tried to connect as an AiMesh Node but it wanted 192.168.1.1 on boot (same as RT-AX88U)… can’t be a*sed for the rest of the day. May look into tomorrow when the natives are all sleeping and no moaning about no internet….
    #11321
    First factory reset Aimesh-Node, then it should work. Before save config to go back easily like it is right now just in case.
    I suppose you still have it configured as master like new one.
    #11328
    [quote quote=11320]Decided to splash out on a RT-AX88U (connected to HG612 3B). Superb performance from the router but still to try out Wifi6 (phone and laptop support natively). The RT-AC88U I tried to connect as an AiMesh Node but it wanted 192.168.1.1 on boot (same as RT-AX88U)… can’t be a*sed for the rest of the day. May look into tomorrow when the natives are all sleeping and no moaning about no internet….[/quote]
    The RT-AX88U arrived quickly, are / have you flashed the any of your two routers with ASUSWRT-Merlin firmware ?
    Families and Internet access, especially during lockdown
    #11329
    Avatarn13ldo
    • Replies 31
    [quote quote=11328]
    The RT-AX88U arrived quickly, are / have you flashed the any of your two routers with ASUSWRT-Merlin ? Families and Internet access [/quote]
    Yep, both on latest Merlin. The RT-AX88U was on 192.168.50.1 out of the box (factory). Couldn’t find it initially.
    I run PiHole on a Linux Mint machine as DHCP/DNS which makes swapping out routers fairly quick – and no ads on the network to boot.
    #11330
    Perfect and sounds like you know what you are doing and try as @Grisu advice’s as he is very knowledgeable
    #11331
    Yes RTFM, they use different default IP on newer routers 50.1 instead of 1.1 on older routers. You find it in manual and help.
    #11336
    Avatarn13ldo
    • Replies 31
    [quote quote=11331]Yes RTFM, they use different default IP on newer routers 50.1 instead of 1.1 on older routers. You find it in manual and help.[/quote]
    RTFM indeed
    Didn’t notice the downstream router should be using the WAN port, doh!
    #11351
    If everyone RTFM, There would be no need for any forums
    #11424
    AvatarDSLit
    • Replies 1
    [quote quote=10349]
    Chris Best wrote: Hi @uk-sentinel, if at all possible would i be able to get access to the telnet firmware build, having some weird issues with my AC-88u and would like to see if i can get to the bottom of it. ta in advance. Hi @chrisbest – email / PM sent about firmware
    Hi, may I have it too?
    Hi @zer000 – email / PM sent about firmware[/quote]
    Hello @uk-sentinel, Can I have the telnet firmware too?
    I have the DSL-AC-88U.
    Many thanks!
    #11426
    @DSLit – I have sent you an email
    #11819
    [quote quote=11157]
    Ditching the DSL-AC88U is my advice and purchase something like the RT-AC88U or RT-AC86U is a safer option, alas then u will need a G.fast modem such as Draytek 166 ? (I think you had G.fast) I forget ?
    Good memory, its sure better than mine I think that I have reached the same conclusion but I was thinking that I could connect the MT995 to the RT-AC88U ? At moment I just have a Cat6 from my MT995 into the WAN port of my DSL-AC88U & I thought I would be able to do the same with the RT-AC88U[/quote]
    @andyshaw
    , when you get a moment, not sure how far you got with your DSL-AC88U VPN crusade, but another forum member has similar issues with same ISP I believe?
    Asus DSL-AC88U VPN issues
    #12063
    Avataremantec
    • Replies 5
    [/quote][quote quote=11426] @DSLit – I have sent you an email [/quote]
    Could I grab a copy as well? Thanks.
    #12066
    @emantec  You was sent the link on the 15/09/2020 to your registered email address
    #12067
    Avataremantec
    • Replies 5
    [quote quote=12066] @emantec You was sent the link on the 15/09/2020 to your registered email address[/quote]
    Yeah, unfortunately it went into my spam folder and has since been deleted. Could I get the link again?
    #12068
    No problem, Another email has been sent
