› UKTH forums › 🛜 Wireless Routers & Modems › ASUS & Wireless › Asus RT-AX88U / Pro – Firmware Updates Thread ============================ Router Model – Asus RT-AX88U Firmware Version – 3.0.0.4.384.7756 Firmware Release Date – 2019/11/25 ============================ Changelog – – Enhanced the Wi-Fi 6 performance with Apple® iPhone11, Samsung® S10. –...
- This topic has 138 replies, 7 voices, and was last updated 1 week, 4 days ago by
- December 21, 2019 at 12:37 pm #5514
Thanks for your input, this is what I try to say from the beginning but looks like some of the info been lost…
I connect to 2.4 network because is faster upstairs then 5g, on previous routers was opposite, as supposed to be. When I connect my LG v30 to 5G link speed is 866Mb/s but speed test getting only 45Mb/s even then I sit 2 meters away from router. Upstairs I got 500Mb/s plus – link speed, but speedtest getting ridiculous 2-3Mb/s,on 2.4g I got slightly better. To my 5G network are connected only my pc and my son as these two are only able to use full bandwidth capability, don’t have idea why? My pc for now (will be changed soon) got Asus pce-ac68 card and sync with 1.3Gb/s I can get full broadband speed, my son card is with realtek chip and he got around 1.1-1.3Gb/s link with full speed achievable through speedtest.
I don’t really need to connect other devices to 5G for now, once became more “powerful” I will switch to it rest of smart TVs.
December 21, 2019 at 1:02 pm #5519ok
i might think 2.4ghz might be culprit lol , i have hardly ever tested 5ghz device on 2.4 ghz …. but i use smart connect .. so it auto connect to 2.4 ghz or 5ghz as per situation
u can also try moving to 40Mhz Channel on 2.4 Ghz and see if speed increase
oron 5ghz professional settings .. enable Multi user MIMO , 802.11AC Beam forming .. than reboot and connect those device on 5ghz and check speed ?
i would prefer moving to 5ghz channel because it got most bandwidth available with less interference …….
PCE-AC68 is 3×3 stream device = 1,300 Mbps is max it will get at 80Mhz channel bandwidth which is good and according to expectation
December 21, 2019 at 1:16 pm #5520I got set 2.4 to 20/40Mhz, I tried yesterday with 5g and 80Mhz with mu mimo and beam forming, rebooted router make no difference on my mobile. I may be wrong but I think mu mimo working only with devices which support it? I don’t think any devices in my house support this?
I wonder if protect management frame don’t cause this issue? When I tested my mobile on other router which don’t have this all was O.K.
It shows on screenshot that non other devices got this, I believe is (pmf-opt), and for some reason I can’t turn this off.
December 21, 2019 at 2:56 pm #5523I did another test to compare, laptop in far corner of my bedroom and my mobile, booth connected to 5G, as you can see on screenshot mobile phone much better connection (laptop with intel card), where on laptop speedtest give me results of D-72.19Mb/s and U-18.48,mobile phone give D-2.55Mb/s and U-5.35Mb/s, how wired is that?
Edit
Found some more info, so maybe that is my problem?
https://www.snbforums.com/threads/protected-management-frames.15584/
December 21, 2019 at 4:00 pm #5526hmm @ that data rate your phone will easily support 250Mbps+
ok lets see … my settings are like …
wifi – general tab
802.11ax/ Wi-fi 6 mode -> Enable
WPA Encryption – AES
Authentication Method – WPA2 Personal
Protected Management Frames – Capable ( on previous firmware it was disable )
Channel bandwidth – 20/40/80 ( unchecked 160MHz and DFS )
Control Channel – 36WPS Tab ->
WPS – OffProfessional Tab
Region Set to -> Asiayour phone SOC Snapdragon 835 does support – MU-MIMO … ( but not sure if LG enabled it or not on software side )
– https://www.qualcomm.com/products/snapdragon-835-mobile-platformYou need to login in order to vote
December 21, 2019 at 4:57 pm #5527I got nearly exact settings apart of channel set to 44 (neighbours around don’t use this one) and I don’t have option for region settings.
You said that it was possible to disable protected management frame in previous fw, was that 384.13?
December 21, 2019 at 5:08 pm #5528When I loaded ASUSWRT-Merlin 384.14 for my RT-AC86U – Protected Management Frames – was disabled by default and can be set o disabled > capable > required
PMF only works with specific hardware formats and for normal home usage, disable is easier.
Keep it simple “KIS”
December 21, 2019 at 5:18 pm #5529I can choose all three options but only option “disable” not saving.
@XRW
You are my Hero, or early Santa 😆
Just done dirty flash to 384.13 and I was able to disable on booth 2.4 and 5Ghz and is actually save the settings, all back to how it should be, 70Mb/s download speed on mobile.Thanks a lot!!!
December 21, 2019 at 5:21 pm #5532When I loaded ASUSWRT-Merlin 384.14 for my RT-AC86U – Protected Management Frames – was disabled by default and can be set o disabled > capable > required PMF only works with specific hardware formats and for normal home usage, disable is easier. Keep it simple “KIS”
Trouble is that on rt-ax88u on latest Merlin fw I couldn’t save “disable” option, other two was O.K to save.
Now all back to normal 🤩
December 21, 2019 at 5:33 pm #5533I see, A bug with 384.14 for the RT-AX88U ;-) I wonder if that is the same with ASUSWRT Stock firmware ?
December 21, 2019 at 5:48 pm #5534I didn’t tried really on stock, original fw on my rt-ax88u was for 5 mins when was powered first time 😂
Since then on Merlin all the time.
December 21, 2019 at 5:57 pm #5536I didn’t tried really on stock, original fw on my rt-ax88u was for 5 mins when was powered first time 😂 Since then on Merlin all the time.
December 22, 2019 at 3:24 am #5543glad everything is sorted out for you :)
ASUS Stock 3.0.0.4.384.6436 where it’s changed ..because of push towards WPA3 and OFDMA …. when you enable WPA3 ..you will need Protected Management Frames Enable/ Capable .. ( through in 384.6436 WP384.6436 WPA3 and OFDMA was not shown as options )
it’s weird that you were not able to save disable option maybe GUI bug … ( through you should report PMF issue to ASUS by feedback form on your router that your phone get very slow speed when PMF is Enable or Capable on 5GHz ….. because WIFI stuff is closed source and fully controlled by ASUS …. )
December 22, 2019 at 8:20 am #5544I posted this info on SNB forum, I didn’t see feedback option on Merlin fw. My hw version is 1.1.
So far all nice and smooth on 384.13, since yesterday no issues at all.
December 22, 2019 at 8:44 am #5545No Feedback option via ASUSWRT-Merlin, only official (Stock) ASUSWRT has this option.
