Viewing 15 posts - 286 through 300 (of 718 total)
  • #6909
    • Replies 8,717
    Did access Problem only started after you used second cable option ?
    #6910
    Bully
    • Replies 386
    Yeah, well not sure because i setup second cable option straight after i updated router firmware.
    #6912
    AvatarMrk26
    • Replies 465
    Agree with @Uk Sentinel, even you get different modem with broadcom chipset is not guarantee any better than you got now. Dsl-ac88u have really good chipset for Vdsl connection, but only that. On my line modem with lantiq chipset sync about 3-4Mb faster than any broadcom based modem. Even famous zyxel VMG1312-B10A sync lower than any lantiq based modem I tried on my line. Also if you get fastpath on downstream lantiq based modem is better as FEC are still on downstream which help reduce CRC (at least in my case) especially where you are on ECI cabinet. This is what G.inp enable on Huawei cabinet on broadcom based modems. I think HG612 maybe good to mantain line till you get fastpath, and then you maybe able to switch back to vigor, this is how I used to do with zyxel.
    #6914
    AvatarMrk26
    • Replies 465
    [quote quote=6910]Yeah, well not sure because i setup second cable option straight after i updated router firmware.[/quote]
    Did you reboot router after you configure second cable option.
    #6915
    • Replies 8,717
    Second cable option was probable the cause, go back to what works, for now
    #6916
    • Replies 8,717
    Fastpath I do not think will happen with your amount of errors – so the speed you get, will probable not change until underlying line noise / faceplate(possible damage)  is addressed.
    #6918
    Bully
    • Replies 386
    [quote quote=6915]
    Second cable option was probable the cause, go back to what works, for now[/quote]
    I have gone back to what was working, but still cannot login to router via its ip address.
    #6919
    • Replies 8,717
    Did you change Router IP / WAN address to Automatic, or back to manual, I forget ?
    If Manual try 192.168.1.2 to access router, as you have changed a few settings and not sure where we are etc. especially if router was not rebooted after config changes etc ?
    #6920
    AvatarMrk26
    • Replies 465
    [quote quote=6916]Fastpath I do not think will happen with your amount of errors – so the speed you get, will probable not change until underlying line noise / faceplate is addressed.[/quote]
    Totally agree, I will disconnect telephone line extension and give couple of hours(literally couple) and see how stats looks like, if that’s the case it will show up immediately. If @Bully keep amount of disconnections below 10 per day DLM shouldn’t action.
    #6921
    • Replies 8,717
    [quote quote=6920]
    Totally agree, I will disconnect telephone line extension and give couple of hours(literally couple) and see how stats looks like, if that’s the case it will show up immediately. If @Bully keep amount of disconnections below 10 per day DLM shouldn’t action.[/quote]
      so you think modem is disconnecting multiple times during the day (I am a little lost) ?
    #6922
    AvatarMrk26
    • Replies 465
    No, I mean, if modem need to be disconnected, it can be few times during the day but less than 10 times. Like swapping modems, change socket etc.
    I was agree about noise and possibly faulty faceplate, I may be wrong but if @Bully had worse results on extension phone this mean for me that filtered signal is not filtered properly.
    #6923
    Bully
    • Replies 386
    Ui on Asus keeps going funny ? –
    #6925
    AvatarMrk26
    • Replies 465
    Try to clear cache, or different browser.
    #6926
    • Replies 8,717
    [quote quote=6922]No, I mean, if modem need to be disconnected, it can be few times during the day but less than 10 times. Like swapping modems, change socket etc [/quote]
    I see, and yes, a few times and DLM will not punish you for disconnects
    [quote quote=6922]. I was agree about noise and possibly faulty faceplate, I may be wrong but if @Bully had worse results on extension phone this mean for me that filtered signal is not filtered properly.[/quote]
    My thoughts also and/or inferior phone cable
    #6927
    • Replies 8,717
    [quote quote=6923]Ui on Asus keeps going funny ? –[/quote]
    Or reboot router / laptop
