Bully.
- May 2, 2020 at 3:00 pm #6929
[quote quote=6927]
Ui on Asus keeps going funny ? –
Or reboot router / laptop[/quote]
Tried that. And still cant login via its lan ip.
May 2, 2020 at 3:09 pm #6930You can check in connection status on laptop what is your gateway IP adress, that should be router ip.
May 2, 2020 at 3:15 pm #6931[quote quote=6930]You can check in connection status on laptop what is your gateway IP adress, that should be router ip.[/quote]
Yeah checked that and is correct.
May 2, 2020 at 3:22 pm #6932May 2, 2020 at 3:25 pm #6933[quote quote=6932]Try this https://router.asus.com:8443/[/quote]
That always works. I still cant connect via its ip though, and this is how i always do it.
May 2, 2020 at 3:31 pm #6934Not sure if this an issue because once I’m logged in to router in adress bar it show router.asus.com. Did you have issues before update?
May 2, 2020 at 3:31 pm #6935[quote quote=6934]Not sure if this an issue because once I’m logged in to router in adress bar it show router.asus.com. Did you have issues before update?[/quote]
No, no issues before update.
May 2, 2020 at 7:16 pm #6939I figured out why I could not access router via its ip address, the Local Access Config was set to HTTPS only and not both.
May 3, 2020 at 8:31 am #6941Then use https:// <router-IP-address> instead of http or nothing at all.
May 3, 2020 at 2:00 pm #6950Today’s stats –
xdslcmd info –stats
Status: Showtime
Retrain Reason: 0
Max: Upstream rate = 12239 Kbps, Downstream rate = 50560 Kbps
Bearer: 0, Upstream rate = 12228 Kbps, Downstream rate = 39994 KbpsLink Power State: L0
Mode: VDSL2 Annex B
VDSL2 Profile: Profile 17a
TPS-TC: PTM Mode(0x0)
Trellis: U:ON /D:ON
Line Status: No Defect
Training Status: Showtime
Down Up
SNR (dB): 6.8 6.1
Attn(dB): 19.5 0.0
Pwr(dBm): 13.4 6.7
VDSL2 framing
Bearer 0
MSGc: 18 20
B: 31 238
M: 1 1
T: 64 63
R: 10 16
S: 0.0255 0.6220
L: 13200 3280
D: 1283 1
I: 42 255
N: 42 255
Counters
Bearer 0
OHF: 35968793 444292
OHFErr: 20 0
RS: 926959794 516592
RSCorr: 253116 4
RSUnCorr: 404 0Bearer 0
HEC: 57 0
OCD: 2 0
LCD: 2 0
Total Cells: 2486312448 0
Data Cells: 779755788 0
Drop Cells: 0
Bit Errors: 0 0ES: 7 2655
SES: 0 31
UAS: 26 84483
AS: 88239Bearer 0
INP: 3.50 0.00
INPRein: 0.00 0.00
delay: 8 0
PER: 2.45 9.83
OR: 78.26 21.15
AgR: 40072.04 12248.93Bitswap: 61493/61959 24/24
Total time = 1 days 31 min 5 sec
FEC: 253116 4
CRC: 20 0
ES: 7 2655
SES: 0 31
UAS: 26 84483
LOS: 0 1
LOF: 0 1
LOM: 0 0
Latest 15 minutes time = 1 min 5 sec
FEC: 39 0
CRC: 0 0
ES: 0 0
SES: 0 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
LOM: 0 0
FEC: 866 0
CRC: 0 0
ES: 0 0
SES: 0 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
LOM: 0 0
Latest 1 day time = 31 min 5 sec
FEC: 1235 0
CRC: 0 0
ES: 0 0
SES: 0 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
LOM: 0 0
FEC: 251881 4
CRC: 20 0
ES: 7 2655
SES: 0 31
UAS: 26 84483
LOS: 0 1
LOF: 0 1
LOM: 0 0
Since Link time = 1 days 30 min 37 sec
FEC: 253116 4
CRC: 20 0
ES: 7 2655
SES: 0 31
UAS: 0 84457
LOS: 0 1
LOF: 0 1
LOM: 0 0Stats recorded 03 May 2020 14:57:55
DSL mode: VDSL2 Profile 17a
Status: Showtime
Uptime: 1 day 0 hour 30 min 39 sec
Resyncs: 0 (since 03 May 2020 14:55:52)Downstream Upstream
Connection speed (kbps): 39994 12228
SNR margin (dB): 6.8 6.1
Power (dBm): 13.4 6.7
Interleave depth: 1283 1
INP: 3.50 0
Vectoring status: 5 (VECT_UNCONFIGURED)RSCorr/RS (%): 0.0273 0.0008
May 3, 2020 at 3:25 pm #6951If you fancy a change and have some spare time/cash, have a look at the Fritz!Box 3490 (£40) on Ebay and has Lantiq chipset, you can set it up so gaming is via Fritz!Box (wired) and wifi can be via ASUS router which is double NAT-ed to Fritz!Box.
@Grisu and I really like these units and other units made by AVM, but wifi not as strong as ASUS, so may need to use ASUS for wifi onlyFritz!box 3490 is modem and router combo and looks like a flying saucer
May 3, 2020 at 3:47 pm #6953Could i use my smart hub 2 as a modem only and connect it to my Asus for the router and wifi ?
May 3, 2020 at 3:59 pm #6954[quote quote=6953]Could i use my smart hub 2 as a modem only and connect it to my Asus for the router and wifi ?[/quote]
BT’s Smart Hub 2 does not offer the modem (Bridged) mode – and its DSL chipset is Broadcom and very locked down.
I was just thinking of the Fritz!Box 3490 as this is a well built unit and gives you access to stats etc via UI and manages its own Bitswap / SRA etc so may be of benefit to yourself. (maybe) !
Alas I could not find an online Emulator for the Fritz!Box 3490
Alas not sure what stats the Smart hub gives, but maybe worth a try in the name of science
May 3, 2020 at 4:07 pm #6956[quote quote=6954]
BT’s Smart Hub 2 does not offer the modem (Bridged) mode – and its DSL chipset is Broadcom and very locked down. I was just thinking of the Fritz!Box 3490 as this is a well built unit and gives you access to stats etc via UI and manages its own Bitswap / SRA etc so may be of benefit to yourself. (maybe) ! Alas I could not find an online Emulator for the Fritz!Box 3490 Alas not sure what stats the Smart hub gives, but maybe worth a try in the name of science
[/quote]Some guy claims he has set up modem only mode ? first post here – https://community.bt.com/t5/Home-setup-Wi-Fi-network/Smart-Hub-2-as-a-Modem/td-p/1922978
May 3, 2020 at 4:23 pm #6958That’s not really modem only mode, that’s poor imitation of it 😜. From one side may be good when reporting issues to BT so they can do some line test with it but that maybe only one plus of that. I had setup EE smart hub that way, most annoying thing is that you have to keep an eye on that as they can change your settings remotely and it will not work as you wish. 😉
