Bully.
- May 3, 2020 at 4:58 pm #6962
UPnP and NAT-ing could/would be effected and OPEN NAT is something an console gamer wants ;-)
May 4, 2020 at 6:38 pm #6969Today’s stats –
xdslcmd info –stats
Status: Showtime
Retrain Reason: 0
Max: Upstream rate = 12293 Kbps, Downstream rate = 50368 Kbps
Bearer: 0, Upstream rate = 12198 Kbps, Downstream rate = 39994 KbpsLink Power State: L0
Mode: VDSL2 Annex B
VDSL2 Profile: Profile 17a
TPS-TC: PTM Mode(0x0)
Trellis: U:ON /D:ON
Line Status: No Defect
Training Status: Showtime
Down Up
SNR (dB): 6.8 6.1
Attn(dB): 19.5 0.0
Pwr(dBm): 13.3 6.8
VDSL2 framing
Bearer 0
MSGc: 18 20
B: 31 238
M: 1 1
T: 64 63
R: 10 16
S: 0.0255 0.6235
L: 13200 3272
D: 1283 1
I: 42 255
N: 42 255
Counters
Bearer 0
OHF: 27569498 53603
OHFErr: 26 0
RS: 1996597486 87213
RSCorr: 138199 3
RSUnCorr: 557 0Bearer 0
HEC: 112 0
OCD: 4 0
LCD: 4 0
Total Cells: 902541263 0
Data Cells: 176403486 0
Drop Cells: 0
Bit Errors: 0 0ES: 11 2655
SES: 0 31
UAS: 26 86680
AS: 67635Bearer 0
INP: 3.50 0.00
INPRein: 0.00 0.00
delay: 8 0
PER: 2.45 9.85
OR: 78.26 21.09
AgR: 40072.04 12219.06Bitswap: 46337/46630 3/3
Total time = 18 hours 47 min 41 sec
FEC: 138199 3
CRC: 26 0
ES: 11 2655
SES: 0 31
UAS: 26 86680
LOS: 0 1
LOF: 0 1
LOM: 0 0
Latest 15 minutes time = 2 min 41 sec
FEC: 159 0
CRC: 0 0
ES: 0 0
SES: 0 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
LOM: 0 0
FEC: 6871 0
CRC: 1 0
ES: 1 0
SES: 0 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
LOM: 0 0
Latest 1 day time = 18 hours 47 min 41 sec
FEC: 138199 3
CRC: 26 0
ES: 11 2655
SES: 0 31
UAS: 26 86680
LOS: 0 1
LOF: 0 1
LOM: 0 0
Previous 1 day time = 0 sec
FEC: 0 0
CRC: 0 0
ES: 0 0
SES: 0 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
LOM: 0 0
Since Link time = 18 hours 47 min 15 sec
FEC: 138199 3
CRC: 26 0
ES: 11 2655
SES: 0 31
UAS: 0 86654
LOS: 0 1
LOF: 0 1
LOM: 0 0Stats recorded 04 May 2020 19:35:00
DSL mode: VDSL2 Profile 17a
Status: Showtime
Uptime: 18 hours 47 min 45 sec
Resyncs: 0 (since 04 May 2020 19:34:24)Downstream Upstream
Connection speed (kbps): 39994 12198
SNR margin (dB): 6.8 6.1
Power (dBm): 13.3 6.8
Interleave depth: 1283 1
INP: 3.50 0
Vectoring status: 5 (VECT_UNCONFIGURED)RSCorr/RS (%): 0.0069 0.0011
May 4, 2020 at 6:59 pm #6970[quote quote=6969]Latest 15 minutes time = 2 min 41 sec
FEC: 159 0Previous 15 minutes time = 15 min 0 sec
FEC: 6871 0[/quote]
This is your problem, 159 FEC errors within 15 mins are normal, nearly 7k not. Is only two minutes but you getting big burst of errors.
Did you try to disconnect telephone for couple of hours to see if that improve your stats?
May 4, 2020 at 7:08 pm #6972May 5, 2020 at 7:12 am #6975May 5, 2020 at 12:50 pm #6982May 5, 2020 at 12:52 pm #6985Good point
I was wondering if it was worth disabling Bitswap to see if errors reduce as bitswap without monitored tones can be problematic ?
Alas I do not know if the HG612 Broadcom chipset supports monitored tones etc ?
May 5, 2020 at 6:49 pm #6988Phone disconnected for an hour and a half, stats below –
xdslcmd info –stats
Status: Showtime
Retrain Reason: 0
Max: Upstream rate = 12232 Kbps, Downstream rate = 49480 Kbps
Mode: VDSL2 Annex B
Trellis: U:ON /D:ON
Down Up
SNR (dB): 6.5 6.1
Attn(dB): 19.5 0.0
Pwr(dBm): 13.3 6.7
VDSL2 framing
Bearer 0
MSGc: 18 20
B: 31 238
M: 1 1
T: 64 63
R: 10 16
S: 0.0255 0.6235
L: 13200 3272
D: 1283 1
I: 42 255
N: 42 255
Counters
Bearer 0
OHF: 62407926 214562
OHFErr: 49 0
RS: 2489652223 2891526
RSCorr: 371148 4
RSUnCorr: 1395 0Bearer 0
HEC: 257 0
OCD: 10 0
LCD: 10 0
Total Cells: 3175578604 0
Data Cells: 529225626 0
Drop Cells: 0
Bit Errors: 0 0ES: 20 2655
SES: 0 31
UAS: 26 86680
AS: 153102Bearer 0
INP: 3.50 0.00
INPRein: 0.00 0.00
delay: 8 0
PER: 2.45 9.85
OR: 78.26 21.09
AgR: 40072.04 12219.06Bitswap: 104727/105373 9/9
Total time = 1 days 18 hours 32 min 8 sec
FEC: 371148 4
CRC: 49 0
ES: 20 2655
SES: 0 31
UAS: 26 86680
LOS: 0 1
LOF: 0 1
LOM: 0 0
Latest 15 minutes time = 2 min 8 sec
FEC: 225 0
CRC: 0 0
ES: 0 0
SES: 0 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
LOM: 0 0
FEC: 2198 0
CRC: 0 0
ES: 0 0
SES: 0 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
LOM: 0 0
Latest 1 day time = 18 hours 32 min 8 sec
FEC: 158544 0
CRC: 12 0
ES: 6 0
SES: 0 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
LOM: 0 0
FEC: 212604 4
CRC: 37 0
ES: 14 2655
SES: 0 31
UAS: 26 86680
LOS: 0 1
LOF: 0 1
LOM: 0 0
Since Link time = 1 days 18 hours 31 min 41 sec
FEC: 371148 4
CRC: 49 0
ES: 20 2655
SES: 0 31
UAS: 0 86654
LOS: 0 1
LOF: 0 1
LOM: 0 0You need to login in order to vote
May 5, 2020 at 7:08 pm #6989May 5, 2020 at 7:25 pm #6990May 5, 2020 at 7:35 pm #6991Can you produce again the Graph with FEC over 24 hours ( I think you did this previously) but could be wrong as this should help understand if FEC are consistent, or at certain times of the day ?
Example below:
May 5, 2020 at 8:15 pm #6995May 5, 2020 at 8:21 pm #6996On the 3rd May:
FEC: 866 0Coincidence,
May 5, 2020 at 8:26 pm #6997[quote quote=6996]On the 3rd May: Previous 15 minutes time = 15 min 0 sec FEC: 866 0 Coincidence,
[/quote]I was going to edit but you was faster, I was goingto to add unless these values was recorded in smaller burst 😉
May 5, 2020 at 8:31 pm #6998In this case the only way to reduce amount of errors will be put cap on the lime but:
a) if noise on the line is too bad it may not improve enough
b) if improve @Bully may not be able to remove cap completely because as soon he remove his line will be interleaved again.
