Bully.
- May 7, 2020 at 9:44 pm #7070
What is your router ip pool 192.168.??.??
Edit
If pool ending on 254, then change end pool to 250 and set in modem ip to 192.168.xx.251 and it should set gateway ro 252 automatically. So you will use 192.168.xx.251 to login to modem.
May 7, 2020 at 10:02 pm #7073What is your router ip pool 192.168.??.?? Edit If pool ending on 254, then change end pool to 250 and set in modem ip to 192.168.xx.251 and it should set gateway ro 252 automatically. So you will use 192.168.xx.251 to login to modem.
Are there any settings in the modem i need to change?
May 7, 2020 at 10:07 pm #7074If you didn’t changed any settings related to lan etc should be OK, if not sure perform factory reset and it should working. Of course if you perform factory reset you will need to setup IP address in modem.
May 7, 2020 at 10:10 pm #7075If you didn’t changed any settings related to lan etc should be OK, if not sure perform factory reset and it should working. Of course if you perform factory reset you will need to setup IP address in modem.
Great, thank you.
May 7, 2020 at 10:15 pm #7076May 7, 2020 at 10:35 pm #7078May 7, 2020 at 10:39 pm #7079What is now?
Wan ip is 192.168.X.2 and default gateway is 192.168.X.1, the X is different to the X on the routers Lan ip address pool.
May 7, 2020 at 10:55 pm #7080So for example your router IP in your lan is 192.168.1.1, you need to setup ip in modem to 192.168.1.251 and it should setup 192.168.1.252 automatically for getaway. In router wan settings you should change to get ip automatically. Also in dhcp end pool on 192.168.1.250. Then you should be able to login to modem. When I used two cable solution on eci modem I always had set to get ip automatically because that is for wan, for lan (which is needed for stats) you use lan to lan connections.
My IP adrress as 192.168.1.1 is example only, where yours 192.168.x.1 where “x” must be the same in modem and router, they have to be in the same IP pool otherwise you won’t be able to access modem as asus won’t be able to connect to device from outside of lan IP pool.
May 7, 2020 at 10:56 pm #7081Once is set like that you will access to modem from IP 192.168.x.251.
May 7, 2020 at 10:58 pm #7082So for example your router IP in your lan is 192.168.1.1, you need to setup ip in modem to 192.168.1.251 and it should setup 192.168.1.252 automatically for getaway. In router wan settings you should change to get ip automatically. Also in dhcp end pool on 192.168.1.250. Then you should be able to login to modem. When I used two cable solution on eci modem I always had set to get ip automatically because that is for wan, for lan (which is needed for stats) you use lan to lan connections. My IP adrress as 192.168.1.1 is example only, where yours 192.168.x.1 where “x” must be the same in modem and router, they have to be in the same IP pool otherwise you won’t be able to access modem as asus won’t be able to connect to device from outside of lan IP pool.
Great, it is clear now, i thought i have to manually assign wan ip in router, but i have to set it to get wan ip automatically.
May 7, 2020 at 11:04 pm #7083Yes, this setup is different than on vigor as you access vigor through wan port so you have to assign IP, on two cables connection you don’t worry about wan, you have to setup lan access.
May 8, 2020 at 7:55 am #7089All changed and setup, i can access modem via router and dslstats runs too.
May 8, 2020 at 7:59 am #7090All changed and setup, i can access modem via router and dslstats runs too.
May 8, 2020 at 8:05 am #7091All changed and setup, i can access modem via router and dslstats runs too.
Thanks again for help.
May 8, 2020 at 9:06 am #7092xdslcmd info –stats
Status: Showtime
Retrain Reason: 0
Max: Upstream rate = 12168 Kbps, Downstream rate = 50368 Kbps
Bearer: 0, Upstream rate = 12198 Kbps, Downstream rate = 39994 KbpsLink Power State: L0
Mode: VDSL2 Annex B
VDSL2 Profile: Profile 17a
TPS-TC: PTM Mode(0x0)
Trellis: U:ON /D:ON
Line Status: No Defect
Training Status: Showtime
Down Up
SNR (dB): 6.8 6.0
Attn(dB): 19.5 0.0
Pwr(dBm): 13.3 6.8
VDSL2 framing
Bearer 0
MSGc: 18 20
B: 31 238
M: 1 1
T: 64 63
R: 10 16
S: 0.0255 0.6235
L: 13200 3272
D: 1283 1
I: 42 255
N: 42 255
Counters
Bearer 0
OHF: 154514838 1014454
OHFErr: 102 0
RS: 3498967787 699486
RSCorr: 1132662 10
RSUnCorr: 5088 0Bearer 0
HEC: 887 0
OCD: 46 0
LCD: 46 0
Total Cells: 3360127889 0
Data Cells: 1104242160 0
Drop Cells: 0
Bit Errors: 0 0ES: 38 2655
SES: 0 31
UAS: 26 86680
AS: 379058Bearer 0
INP: 3.50 0.00
INPRein: 0.00 0.00
delay: 8 0
PER: 2.45 9.85
OR: 78.26 21.09
AgR: 40072.04 12219.06Bitswap: 258611/260264 27/28
Total time = 1 days 9 hours 18 min 4 sec
FEC: 1132662 10
CRC: 102 0
ES: 38 2655
SES: 0 31
UAS: 26 86680
LOS: 0 1
LOF: 0 1
LOM: 0 0
Latest 15 minutes time = 3 min 4 sec
FEC: 587 0
CRC: 0 0
ES: 0 0
SES: 0 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
LOM: 0 0
FEC: 2403 0
CRC: 0 0
ES: 0 0
SES: 0 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
LOM: 0 0
Latest 1 day time = 9 hours 18 min 4 sec
FEC: 90880 0
CRC: 0 0
ES: 0 0
SES: 0 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
LOM: 0 0
FEC: 277357 1
CRC: 19 0
ES: 7 0
SES: 0 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
LOM: 0 0
Since Link time = 4 days 9 hours 17 min 37 sec
FEC: 1132662 10
CRC: 102 0
ES: 38 2655
SES: 0 31
UAS: 0 86654
LOS: 0 1
LOF: 0 1
LOM: 0 0DSLAM type / SW version: IFTN:0xd086 (208.134) / v0xd086
DSL mode: VDSL2 Profile 17a
Status: Showtime
Uptime: 4 days 9 hours 17 min 38 sec
Resyncs: 0 (since 08 May 2020 08:59:47)Downstream Upstream
Connection speed (kbps): 39994 12198
SNR margin (dB): 6.8 6.0
Power (dBm): 13.3 6.8
Interleave depth: 1283 1
INP: 3.50 0
Vectoring status: 5 (VECT_UNCONFIGURED)RSCorr/RS (%): 0.0324 0.0014
RSUnCorr/RS (%): 0.0001 0.0000
