Bully.
- May 8, 2020 at 7:38 pm #7122
I don’t have option to plug into test socket, no power socket cloese to it. That’s why is connected as it is now. If I would like to connect to test socket I will have to disconnect cable from back of the faceplate and hardwire bt plug to it, or get extension lead and plug modem there straight on the front of my door (I beat they did it for purpose). Because I don’t have issues now this never came across my mind. My modem running for over 50h now and I got about 12k FEC errors, so nothing to complain, just waiting for fastpath.
May 8, 2020 at 7:52 pm #7123May 9, 2020 at 8:58 am #7124Ping has raised. Interleaving has risen. I will cap speed today.
xdslcmd info –stats
Status: Showtime
Retrain Reason: 1
Max: Upstream rate = 12168 Kbps, Downstream rate = 50784 Kbps
Bearer: 0, Upstream rate = 12022 Kbps, Downstream rate = 37871 KbpsLink Power State: L0
Mode: VDSL2 Annex B
VDSL2 Profile: Profile 17a
TPS-TC: PTM Mode(0x0)
Trellis: U:ON /D:ON
Line Status: No Defect
Training Status: Showtime
Down Up
SNR (dB): 6.9 6.2
Attn(dB): 19.6 0.0
Pwr(dBm): 13.2 6.7
VDSL2 framing
Bearer 0
MSGc: 15 20
B: 25 238
M: 1 1
T: 64 31
R: 10 16
S: 0.0218 0.6326
L: 13184 3225
D: 2803 1
I: 36 255
N: 36 255
Counters
Bearer 0
OHF: 3947213 989207
OHFErr: 0 0
RS: 1768172206 1172006
RSCorr: 32563 0
RSUnCorr: 0 0Bearer 0
HEC: 0 0
OCD: 0 0
LCD: 0 0
Total Cells: 705943399 0
Data Cells: 3022842 0
Drop Cells: 0
Bit Errors: 0 0ES: 1645 5310
SES: 11 62
UAS: 61 173464
AS: 9696Bearer 0
INP: 8.50 0.00
INPRein: 0.00 0.00
delay: 15 0
PER: 2.45 9.84
OR: 68.39 21.13
AgR: 37938.91 12043.54Bitswap: 6520/6552 0/0
Total time = 18 hours 26 min 53 sec
FEC: 16341079 68
CRC: 40071 0
ES: 1645 5310
SES: 11 62
UAS: 61 173464
LOS: 1 2
LOF: 10 2
LOM: 0 0
Latest 15 minutes time = 11 min 53 sec
FEC: 1215 0
CRC: 0 0
ES: 0 0
SES: 0 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
LOM: 0 0
FEC: 673 0
CRC: 0 0
ES: 0 0
SES: 0 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
LOM: 0 0
Latest 1 day time = 18 hours 26 min 53 sec
FEC: 16341079 68
CRC: 40071 0
ES: 1645 5310
SES: 11 62
UAS: 61 173464
LOS: 1 2
LOF: 10 2
LOM: 0 0
Previous 1 day time = 0 sec
FEC: 0 0
CRC: 0 0
ES: 0 0
SES: 0 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
LOM: 0 0
Since Link time = 2 hours 41 min 35 sec
FEC: 32563 0
CRC: 0 0
ES: 0 2655
SES: 0 31
UAS: 0 86723
LOS: 0 1
LOF: 0 1
LOM: 0 0DSLAM type / SW version: IFTN:0xd086 (208.134) / v0xd086
DSL mode: VDSL2 Profile 17a
Status: Showtime
Uptime: 2 hours 42 min 5 sec
Resyncs: 0 (since 09 May 2020 09:54:22)Downstream Upstream
Line attenuation (dB): 19.6 0.0
Connection speed (kbps): 37871 12022
SNR margin (dB): 6.9 6.2
Power (dBm): 13.2 6.7
Interleave depth: 2803 1
INP: 8.50 0
Vectoring status: 5 (VECT_UNCONFIGURED)RSCorr/RS (%): 0.0018 0.0000
May 9, 2020 at 9:14 am #7125Well after over 16 milions FEC errors, over 40k CRC, and 16 hundreds ES, I’m personally not surprised…
[quote quote=7117]
To much tinkering – DLM is the Governor ;-) [/quote]
Looks like my crystal ball is well synchronized with DLM.
May 9, 2020 at 9:16 am #7126I have applied the cap, i will leave it a couple of hours and update stats later today.
Off to play some COD MW.
May 9, 2020 at 9:17 am #7128May 9, 2020 at 9:19 am #7129[quote quote=7128]What cap you applied.[/quote]
The one you advised previously in this thread – xdslcmd configure –maxDataRate 35000 12000 100000
May 9, 2020 at 9:22 am #7130Keep an eye on stats for next max 2h, if stats don’t improve you may have to cap down to 30Mb.
May 9, 2020 at 12:19 pm #7131Almost 3 hrs running dslstats. I was on the phone from 10.30 am to 11.oo am and i noticed a lot of noise and the person on the other end of the call could here it.
Status: Showtime
Uptime: 3 hours 9 min 17 sec
Resyncs: 0 (since 09 May 2020 10:23:23)Downstream Upstream
Connection speed (kbps): 34999 11999
SNR margin (dB): 8.4 6.0
Power (dBm): 13.3 6.8
Interleave depth: 1485 1
INP: 8.00 0
Vectoring status: 5 (VECT_UNCONFIGURED)RSCorr/RS (%): 0.0011 0.0000
ES/hour: 0 809xdslcmd info –stats
Status: Showtime
Retrain Reason: 1
Max: Upstream rate = 12090 Kbps, Downstream rate = 50072 Kbps
Bearer: 0, Upstream rate = 11999 Kbps, Downstream rate = 34999 KbpsLink Power State: L0
Mode: VDSL2 Annex B
Trellis: U:ON /D:ON
Down Up
SNR (dB): 8.4 6.0
Attn(dB): 19.6 0.0
Pwr(dBm): 13.3 6.8
VDSL2 framing
Bearer 0
MSGc: 18 159
B: 47 236
M: 1 1
T: 61 2
R: 16 16
S: 0.0436 0.6283
L: 11736 3247
D: 1485 1
I: 64 255
N: 64 255
Counters
Bearer 0
OHF: 4250616 1095891
OHFErr: 0 0
RS: 1037060534 3579376
RSCorr: 11427 0
HEC: 0 0
OCD: 0 0
LCD: 0 0
Total Cells: 763672213 0
Data Cells: 175417408 0
Drop Cells: 0
Bit Errors: 0 0ES: 1645 7965
SES: 11 93
UAS: 98 260258
AS: 11357Bearer 0
INP: 8.00 0.00
INPRein: 0.00 0.00
delay: 16 0
PER: 2.67 10.40
OR: 71.86 126.83
AgR: 35071.00 12125.70Bitswap: 7125/7126 3/3
Total time = 21 hours 50 min 25 sec
FEC: 16353553 68
CRC: 40071 0
ES: 1645 7965
SES: 11 93
UAS: 98 260258
LOS: 1 3
LOF: 10 3
LOM: 0 0
Latest 15 minutes time = 5 min 25 sec
FEC: 1097 0
CRC: 0 0
ES: 0 0
SES: 0 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
LOM: 0 0
FEC: 752 0
CRC: 0 0
ES: 0 0
SES: 0 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
LOM: 0 0
Latest 1 day time = 21 hours 50 min 25 sec
FEC: 16353553 68
CRC: 40071 0
ES: 1645 7965
SES: 11 93
UAS: 98 260258
LOS: 1 3
LOF: 10 3
LOM: 0 0
FEC: 0 0
CRC: 0 0
ES: 0 0
SES: 0 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
LOM: 0 0
Since Link time = 3 hours 9 min 17 sec
FEC: 11427 0
CRC: 0 0
ES: 0 2655
SES: 0 31
UAS: 0 86757
LOS: 0 1
LOF: 0 1
LOM: 0 0You need to login in order to vote
May 9, 2020 at 1:28 pm #7135total of 4 hours now –
xdslcmd info –stats
Status: Showtime
Retrain Reason: 1
Max: Upstream rate = 12132 Kbps, Downstream rate = 50280 Kbps
Mode: VDSL2 Annex B
Trellis: U:ON /D:ON
Down Up
SNR (dB): 8.4 6.1
Attn(dB): 19.6 0.0
Pwr(dBm): 13.2 6.8
VDSL2 framing
Bearer 0
MSGc: 18 159
B: 47 236
M: 1 1
T: 61 2
R: 16 16
S: 0.0436 0.6283
L: 11736 3247
D: 1485 1
I: 64 255
N: 64 255
Counters
Bearer 0
OHF: 5777785 1489446
OHFErr: 0 0
RS: 1409689949 3773430
RSCorr: 14700 1
HEC: 0 0
OCD: 0 0
LCD: 0 0
Total Cells: 1038032709 0
Data Cells: 182649529 0
Drop Cells: 0
SES: 11 93
UAS: 98 260258
AS: 15437Bearer 0
INP: 8.00 0.00
INPRein: 0.00 0.00
delay: 16 0
PER: 2.67 10.40
OR: 71.86 126.83
AgR: 35071.00 12125.70Bitswap: 10328/10328 3/3
Total time = 22 hours 58 min 25 sec
FEC: 16356826 69
CRC: 40071 0
ES: 1645 7965
SES: 11 93
UAS: 98 260258
LOS: 1 3
LOF: 10 3
LOM: 0 0
Latest 15 minutes time = 13 min 25 sec
FEC: 243 0
CRC: 0 0
ES: 0 0
SES: 0 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
LOM: 0 0
FEC: 511 1
CRC: 0 0
ES: 0 0
SES: 0 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
LOM: 0 0
Latest 1 day time = 22 hours 58 min 25 sec
FEC: 16356826 69
CRC: 40071 0
ES: 1645 7965
SES: 11 93
UAS: 98 260258
LOS: 1 3
LOF: 10 3
LOM: 0 0
FEC: 0 0
CRC: 0 0
ES: 0 0
SES: 0 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
LOM: 0 0
Since Link time = 4 hours 17 min 15 sec
FEC: 14700 1
CRC: 0 0
ES: 0 2655
SES: 0 31
UAS: 0 86757
LOS: 0 1
LOF: 0 1
Status: Showtime
Uptime: 4 hours 18 min 17 sec
Power (dBm): 13.2 6.8
INP: 8.00 0
Vectoring status: 5 (VECT_UNCONFIGURED)RSCorr/RS (%): 0.0010 0.0000
ES/hour: 0 599Attachments:
May 9, 2020 at 1:36 pm #7137It’s definitely better. Let’s hope DLM will reduce interleave shortly.
May 10, 2020 at 2:22 pm #71485 hr graph and stats –
xdslcmd info –stats
Status: Showtime
Retrain Reason: 1
Max: Upstream rate = 12093 Kbps, Downstream rate = 50480 Kbps
Mode: VDSL2 Annex B
Trellis: U:ON /D:ON
Down Up
SNR (dB): 8.5 6.0
Attn(dB): 19.6 0.0
Pwr(dBm): 13.2 6.8
VDSL2 framing
Bearer 0
MSGc: 18 159
B: 47 236
M: 1 1
T: 61 2
R: 16 16
S: 0.0436 0.6283
L: 11736 3247
D: 1485 1
I: 64 255
N: 64 255
Counters
Bearer 0
OHF: 39059231 356055
OHFErr: 20 0
RS: 940428043 2887475
RSCorr: 189953 6
RSUnCorr: 2207 0Bearer 0
HEC: 609 0
OCD: 18 0
LCD: 18 0
Total Cells: 2722210926 0
Data Cells: 383768778 0
Drop Cells: 0
Bit Errors: 0 0ES: 1648 7965
SES: 11 93
UAS: 98 260258
AS: 104354Bearer 0
INP: 8.00 0.00
INPRein: 0.00 0.00
delay: 16 0
PER: 2.67 10.40
OR: 71.86 126.83
AgR: 35071.00 12125.70Bitswap: 79017/79017 31/31
Total time = 1 days 23 hours 40 min 22 sec
FEC: 16532079 74
CRC: 40091 0
ES: 1648 7965
SES: 11 93
UAS: 98 260258
LOS: 1 3
LOF: 10 3
LOM: 0 0
Latest 15 minutes time = 10 min 22 sec
FEC: 47 0
CRC: 0 0
ES: 0 0
SES: 0 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
LOM: 0 0
FEC: 1591 0
CRC: 0 0
ES: 0 0
SES: 0 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
LOM: 0 0
Latest 1 day time = 23 hours 40 min 22 sec
FEC: 148865 5
CRC: 20 0
ES: 3 0
SES: 0 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
LOM: 0 0
FEC: 16383214 69
CRC: 40071 0
ES: 1645 7965
SES: 11 93
UAS: 98 260258
LOS: 1 3
LOF: 10 3
LOM: 0 0
Since Link time = 1 days 4 hours 59 min 13 sec
FEC: 189953 6
CRC: 20 0
ES: 3 2655
SES: 0 31
UAS: 0 86757
LOS: 0 1
LOF: 0 1
Status: Showtime
Uptime: 1 day 4 hours 59 min 14 sec
Resyncs: 0 (since 10 May 2020 10:04:50)Downstream Upstream
SNR margin (dB): 8.5 6.0
INP: 8.00 0
Vectoring status: 5 (VECT_UNCONFIGURED)RSCorr/RS (%): 0.0202 0.0002
RSUnCorr/RS (%): 0.0002 0.0000
ES/hour: 0 0Attachments:
May 10, 2020 at 3:02 pm #7150Looking on graph you getting regular bursts.
I can’t remember, did you tried to plug modem direct to master socket.
May 10, 2020 at 3:05 pm #7151[quote quote=7150]Looking on graph you getting regular bursts. I can’t remember, did you tried to plug modem direct to master socket.[/quote]
No not yet.
May 10, 2020 at 3:17 pm #7152I think that maybe next move. Your stats now don’t looking too bad, but not good enough (in my opinion). With snr 8.5 db you should get barely any errors, and on your line still quite lot appears. If you connect modem to master socket direct (with cap like you have now) for at least couple of hours you should get good picture to compare with current stats.
