Viewing 15 posts - 91 through 105 (of 718 total)
  • #6534
    • Replies 8,710
    Bitswap Near End is Off, run the Telnet command again to get it back On
    #6537
    Bully
    • Replies 386
    Should i leave it off as my FEC errors seem to have dropped?
    I cant seem to add images from Imgur using BB codes?
    #6538
    AvatarMrk26
    • Replies 465
    Don’t turn on bitswap by telnet. Wait, they will turn on automatically.
    #6539
    • Replies 8,710
    Images are limited to 1Mb – try for a while leaving it Off, just incase that works, but I would assume your CRC will increase ?
    #6540
    Bully
    • Replies 386
    Does the below mean 0 = on as default?
    bitswap      [US] =      1, [DS] =      1.
    [0: default(ON), 1: ON, 2: OFF]
    #6541
    • Replies 8,710
    [quote quote=6538]Don’t turn on bitswap by telnet. Wait, they will turn on automatically.[/quote]
    Does that take 4 hours for Bitswap to be enabled ?
    #6542
    AvatarMrk26
    • Replies 465
    Within 2h max 3h should be on. I realised that telnet adjustment on vigor may cause issues.
    #6543
    • Replies 8,710
    [quote quote=6542]Within 2h max 3h should be on. I realised that telnet adjustment on vigor may cause issues.[/quote]
    @bully
    modem has been on for 4 hours and Bitswap was Off for Near End – hence recommendation to enable via Telnet ?
    #6545
    Bully
    • Replies 386
    Been on from 10am, so approx 5 hrs
    #6546
    Bully
    • Replies 386
    Blue wires to living room phone.
    [img]https://i.imgur.com/CkTXYJ9l.jpg[/img]
    [img]https://i.imgur.com/YX2LWEwl.jpg[/img]
    [img]https://i.imgur.com/wqMdc6Sl.jpg[/img]
    #6548
    • Replies 8,710
    [quote quote=6540]Does the below mean 0 = on as default? bitswap [US] = 1, [DS] = 1. [0: default(ON), 1: ON, 2: OFF][/quote]
    I believe so
    #6549
    • Replies 8,710
    @Bully – I will drop out of this conversation for a while as @Mrk26 and I must be driving you mad with our different advice.
    Hope all goes well as I have a Sunday roast to prepare
    #6550
    AvatarMrk26
    • Replies 465
    @bully
    Do you have anything connected to back of faceplate?
    Also how heavy you use internet now. It’s really strange that bitswap didn’t turn on on downstream.
    @Uk Sentinel
    Aaaaa Sunday roast 🤤
    In generally if bits don’t swap then “bitswap” is not activated.
    Couple of speed test or heavy usage should help to turn them on “naturally” (as per my experience).
    #6552
    Bully
    • Replies 386
    Nope, nothing connected to back of face plate.  So if i am correct, the blue wires to the living room are filtered?
    [img]https://i.imgur.com/c1wPsYp.jpg[/img]
    #6553
    AvatarMrk26
    • Replies 465
    Yes, these are filtered, so basically shouldn’t cause issues….
    And actually you socket is later edition so shouldn’t be issues with it…
