Viewing 15 posts - 106 through 120 (of 718 total)
  • #6556
    AvatarMrk26
    • Replies 465
    [quote quote=6549] @Bully – I will drop out of this conversation for a while as @Mrk26 and I must be driving you mad with our different advice. Hope all goes well as I have a Sunday roast to prepare [/quote]
    I think I will drop faster as a part of trying on different modem, I run out of sensible ideas.
    Maybe one more question, how far you are from cabinet on the street?
    #6559
    Bully
    • Replies 386
    about 650 yards from cabinet.
    #6560
    AvatarMrk26
    • Replies 465
    That could be to far fo vigor to handle stable connection.
    #6561
    Bully
    • Replies 386
    So, the next question is what modem can handle that distance? And i would want one that i can access gui/stats through my router.
    #6562
    AvatarMrk26
    • Replies 465
    The spare one which I got for DLM bad days is recommended zyxel VMG1312-B10A.
    #6563
    AvatarMrk26
    • Replies 465
    Forgot to add that this zyxel is with pre-build vdsl filter which can improve connection on long/noisy lines. Also you can view stats via gui or telnet. Used on ebay shouldn’t be to expensive.
    #6564
    • Replies 8,710
    Or try your old BT HG612 3B Modem as that is also Broadcom DSL chipset as we discussed at beginning of thread – needs re flashing to unlock stats, but easy process
    https://kitz.co.uk/routers/hg612hacking.htm
    Update:
    https://forum.kitz.co.uk/index.php?topic=14262.0
    Firmware is by Howlingwolf and has G.inp enabled but read notes to clarify which option you need
    Direct link to BT HG612 “Howling Wolf” firmware below
    https://mega.nz/folder/LdJFDIJL#e_E1twsIg2kTet8mPjrb4w
    #6565
    AvatarMrk26
    • Replies 465
    AvatarMrk26
    • Replies 465
    @bully
    Did you manage to unlock your HG 612 modem?
    #6575
    Bully
    • Replies 386
    @UK Sentinel – Can I access gui/stats through router on the HG612?
    @Mrk26
    – I think I unlocked it some time ago, checking now.
    #6579
    • Replies 8,710
    If access to modem is not automatic, try this process – https://uktechhub.com/forums/topic/access-to-draytek-vigor-130-modem-stats-from-behind-an-asus-router/
    #6580
    Bully
    • Replies 386
    Ok.
    I had already unlocked the HG612 some time ago with B030SP08 gui version.  Just plugged it into my laptop and set it up in bridged mode and set the ip address to the same as my Draytek, so all i have to do is swap it over (when i am not going to disrupt anyone using the internet) so not sure when that will be.
    Todays Draytek stats –
    DS Actual Rate          : 35000000 bps   US Actual Rate       : 10760000 bps
    DS Attainable Rate      : 44371480 bps   US Attainable Rate   : 10856640 bps
    DS Interleave Depth     :     1520       US Interleave Depth  :        1
    NE Current Attenuation  :       20 dB    Cur SNR Margin       :        5  dB
    DS actual PSD           :     6. 4 dB    US actual PSD        :    13. 2  dB
    NE CRC Count            :        1       FE CRC Count         :     4047
    NE ES Count             :        1       FE  ES Count         :     2647
    Xdsl Reset Times        :        0       Xdsl Link  Times     :        1
    LOS          :      0               0
    FECS         :   4634461            53836 (seconds)
    ES           :      1            2647 (seconds)
    UAS          :     33            83077 (seconds)
    CRC          :      1            4047
    INP          :      0              40 (symbols)
    InterleaveDelay :      0            1500 (1/100 ms)
    NFEC         :    255              61
    LSYMB        :   2887            11974
    INTLVBLOCK   :    255              61
    AELEM        :      0
    [ Counters: Showtime ]
    ElapsedTime  :   77052            77052 (seconds)
    CRC          :      1            4047
    FEC          :   4634484            53836
    HEC          :      0               0
    CRC_P        :      0               0
    CRCP_P       :      0               0
    CVP_P        :      0               0
    ES           :      1            2647
    SES          :      0              31
    LOSS         :      0               1
    UAS          :      0               0
    LOFS         :      0               0
    [ Counters: 15Min ]
    ElapsedTime  :    151             151 (seconds)
    CRC          :      0               0
    FEC          :   1112               0
    HEC          :      0               0
    CRC_P        :      0               0
    CRCP_P       :      0               0
    CVP_P        :      0               0
    ES           :      0               0
    SES          :      0               0
    LOSS         :      0               0
    UAS          :      0               0
    LOFS         :      0               0
    [ Counters: 1DAY ]
    ElapsedTime  :   1951            1951 (seconds)
    CRC          :      0               0
    FEC          :   86644               0
    HEC          :      0               0
    CRC_P        :      0               0
    CRCP_P       :      0               0
    CVP_P        :      0               0
    ES           :      0               0
    SES          :      0               0
    LOSS         :      0               0
    UAS          :      0               0
    LOFS         :      0               0
    #6581
    • Replies 8,710
    Will be an interesting exercise Broadcom vs Lantiq
    #6584
    AvatarMrk26
    • Replies 465
    Should we place bets or that is to obvious? 😉 I personally thing @bully line may be to long for vigor, mine is under 250 mts and is rock solid.
    Edit
    When I looked closer to @bully stats it looks like he is on banded profile, sync exactly 35Mb?
    #6588
    • Replies 8,710
    I hope the results will be a lesson for us all  @Bully is on an ECI (Infineon) Cab, which is why this will be interesting
