Bully.
- May 31, 2020 at 2:06 pm #7780May 31, 2020 at 2:17 pm #7781
Yeah, I was getting worried as the errors seem to have increased a bit.
SRA and G.Vector is still off.
vdsl optn status
trellis [US] = ON, [DS] = ON.
bitswap [US] = 0, [DS] = 0.
[0: default(ON), 1: ON, 2: OFF]
sra [US] = 2, [DS] = 2.
[0: default(=3), 2: OFF, 3: ON , 4: DYNAMIC_SOS]
retx [US] = ON, [DS] = ON.
vpcs 0xff
aelem ON
G.Vector OFF
@uk-sentinel – has your gfast faceplate turned up yet?You need to login in order to vote
May 31, 2020 at 3:12 pm #7783Yeah, I was getting worried as the errors seem to have increased a bit. SRA and G.Vector is still off. vdsl optn status trellis [US] = ON, [DS] = ON. bitswap [US] = 0, [DS] = 0. [0: default(ON), 1: ON, 2: OFF] sra [US] = 2, [DS] = 2. [0: default(=3), 2: OFF, 3: ON , 4: DYNAMIC_SOS] retx [US] = ON, [DS] = ON. vpcs 0xff aelem ON G.Vector OFF @uk-sentinel – has your gfast faceplate turned up yet?
If nothing change by Tuesday you can try to increase snr on downstream, that should keep your line with low amount of errors.
May 31, 2020 at 8:17 pm #7788@uk-sentinel – has your gfast faceplate turned up yet?
I ended up ordering the MK4 Faceplate and NTE5c MK2 Master Socket (2019) with clear Cam Locks
Telephone call causing DSL / Broadband / Internet to drop connection
June 1, 2020 at 5:12 pm #7797———————- ATU-R Info (hw: annex A, f/w: annex A/B/C) ———–
DS Actual Rate : 35000000 bps US Actual Rate : 10801000 bps
DS Attainable Rate : 44844848 bps US Attainable Rate : 10573500 bps
DS Interleave Depth : 1524 US Interleave Depth : 1
NE Current Attenuation : 20 dB Cur SNR Margin : 5 dB
DS actual PSD : 6. 5 dB US actual PSD : 11. 9 dB
NE CRC Count : 0 FE CRC Count : 4104
NE ES Count : 0 FE ES Count : 2674
Xdsl Reset Times : 0 Xdsl Link Times : 2
VDSL Firmware Version : 05-07-09-0F-01-07 [with Vectoring support]
Test Mode : DISABLE
DSLAM CHIPSET VENDOR : < IFTN >
> vdsl status more———————- ATU-R Info (hw: annex A, f/w: annex A/B/C) ———–
Near End Far End Note
Trellis : 1 1
Bitswap : 1 1
ReTxEnable : 0 0
VirtualNoise : 0 0
20BitSupport : 0 0
LatencyPath : 0 0
LOS : 2 0
LOF : 0 0
LPR : 0 0
LOM : 0 0
SosSuccess : 0 0
NCD : 0 0
LCD : 0 0
FECS : 1298076 54977 (seconds)
ES : 0 2674 (seconds)
SES : 0 31 (seconds)
LOSS : 0 1 (seconds)
UAS : 34 89650 (seconds)
HECError : 0 0
CRC : 0 4104
RsCorrection : 0 0
INP : 0 40 (symbols)
InterleaveDelay : 0 1500 (1/100 ms)
NFEC : 255 61
RFEC : 16 16
LSYMB : 2898 11974
INTLVBLOCK : 255 61
AELEM : 0 —-
> vdsl status counts[ Counters: Showtime ]
ElapsedTime : 410551 410551 (seconds)
CRC : 2 4104
FEC : 1298075 54977
HEC : 0 0
CRC_P : 1 0
CRCP_P : 0 0
CVP_P : 0 0
NCD : 0 0
LCD : 0 0
ES : 2 2674
SES : 0 31
LOSS : 0 1
UAS : 0 0
LOFS : 0 0
[ Counters: 15Min ]
ElapsedTime : 771 771 (seconds)
CRC : 0 0
FEC : 2846 0
HEC : 0 0
CRC_P : 0 0
CRCP_P : 0 0
CVP_P : 0 0
NCD : 0 0
LCD : 0 0
ES : 0 0
SES : 0 0
LOSS : 0 0
UAS : 0 0
LOFS : 0 0
[ Counters: 1DAY ]
ElapsedTime : 38571 38571 (seconds)
CRC : 0 0
FEC : 129873 1
HEC : 0 0
CRC_P : 0 0
CRCP_P : 0 0
CVP_P : 0 0
NCD : 0 0
LCD : 0 0
ES : 0 0
SES : 0 0
LOSS : 0 0
UAS : 0 0
June 1, 2020 at 9:33 pm #7798June 2, 2020 at 5:31 pm #7867Movement
DS Actual Rate : 35000000 bps US Actual Rate : 10636000 bps
DS Attainable Rate : 43914336 bps US Attainable Rate : 10669808 bps
DS Interleave Depth : 581 US Interleave Depth : 1
NE Current Attenuation : 20 dB Cur SNR Margin : 7 dB
DS actual PSD : 6. 5 dB US actual PSD : 12. 9 dB
NE CRC Count : 6 FE CRC Count : 4104
NE ES Count : 2 FE ES Count : 2674
Xdsl Reset Times : 0 Xdsl Link Times : 3
Test Mode : DISABLE
Trellis : 1 1
Bitswap : 0 1
ReTxEnable : 0 0
VirtualNoise : 0 0
20BitSupport : 0 0
LatencyPath : 0 0
LOS : 4 0
LOF : 0 0
LPR : 0 0
LOM : 0 0
SosSuccess : 0 0
NCD : 0 0
LCD : 0 0
FECS : 68112 54981 (seconds)
ES : 2 2674 (seconds)
UAS : 34 89685 (seconds)
HECError : 0 0
CRC : 6 4104
RsCorrection : 0 0
INP : 0 15 (symbols)
InterleaveDelay : 0 800 (1/100 ms)
NFEC : 255 76
RFEC : 16 16
LSYMB : 2854 11189
INTLVBLOCK : 255 76
AELEM : 0 —-
ElapsedTime : 486918 486918 (seconds)
CRC : 6 4104
FEC : 68111 54981
HEC : 0 0
CRC_P : 2 0
CRCP_P : 0 0
CVP_P : 0 0
NCD : 0 0
LCD : 0 0
ES : 1 2674
SES : 0 31
LOSS : 0 1
UAS : 0 0
LOFS : 0 0
[ Counters: 15Min ]
ElapsedTime : 87 87 (seconds)
CRC : 0 0
FEC : 1 0
HEC : 0 0
CRC_P : 0 0
CRCP_P : 0 0
CVP_P : 0 0
NCD : 0 0
LCD : 0 0
ES : 0 0
SES : 0 0
LOSS : 0 0
UAS : 0 0
LOFS : 0 0
[ Counters: 1DAY ]
ElapsedTime : 39687 39687 (seconds)
CRC : 4 0
FEC : -1452374 0
HEC : 0 0
CRC_P : 1 0
CRCP_P : 0 0
CVP_P : 0 0
NCD : 0 0
LCD : 0 0
ES : -1 0
SES : 0 0
LOSS : 0 0
UAS : 0 0
June 2, 2020 at 5:45 pm #7868Little steps
Snr on 7db now and interleave delay down from 15ms to 8ms now. So there is a progress
June 2, 2020 at 6:54 pm #7869DS Interleave Depth : 581
was
This is interesting watch this slowly improve
June 2, 2020 at 6:55 pm #7870June 2, 2020 at 6:58 pm #7871June 4, 2020 at 5:24 pm #7895Wind is not good enough yet –
DS Attainable Rate : 44583648 bps US Attainable Rate : 10724344 bps
DS actual PSD : 6. 5 dB US actual PSD : 13. 1 dB
NE CRC Count : 40 FE CRC Count : 4104
NE ES Count : 6 FE ES Count : 2674
Test Mode : DISABLE
Trellis : 1 1
Bitswap : 1 1
ReTxEnable : 0 0
VirtualNoise : 0 0
20BitSupport : 0 0
LatencyPath : 0 0
LOS : 4 0
LOF : 0 0
LPR : 0 0
LOM : 0 0
SosSuccess : 0 0
NCD : 0 0
LCD : 0 0
FECS : 290372 54987 (seconds)
ES : 6 2674 (seconds)
HECError : 0 0
CRC : 40 4104
RsCorrection : 0 0
NFEC : 255 76
RFEC : 16 16
LSYMB : 2854 11189
INTLVBLOCK : 255 76
AELEM : 0 —-
ElapsedTime : 637314 637314 (seconds)
CRC : 40 4104
FEC : 290370 54987
HEC : 0 0
CRC_P : 11 0
CRCP_P : 0 0
CVP_P : 0 0
NCD : 0 0
LCD : 0 0
ES : 5 2674
SES : 0 31
LOSS : 0 1
UAS : 0 0
LOFS : 0 0
[ Counters: 15Min ]
ElapsedTime : 558 558 (seconds)
CRC : 0 0
FEC : 201 0
HEC : 0 0
CRC_P : 0 0
CRCP_P : 0 0
CVP_P : 0 0
NCD : 0 0
LCD : 0 0
ES : 0 0
SES : 0 0
LOSS : 0 0
UAS : 0 0
LOFS : 0 0
[ Counters: 1DAY ]
ElapsedTime : 39258 39258 (seconds)
CRC : 0 0
FEC : 123732 0
HEC : 0 0
CRC_P : 0 0
CRCP_P : 0 0
CVP_P : 0 0
NCD : 0 0
LCD : 0 0
ES : 0 0
SES : 0 0
LOSS : 0 0
UAS : 0 0
June 4, 2020 at 6:24 pm #7896Still much improved on you very first post in this thread regarding stats
June 4, 2020 at 6:29 pm #7897June 6, 2020 at 8:44 am #7903 - AuthorPosts
