- This topic has 1,438 replies, 106 voices, and was last updated 6 months, 1 week ago by
alt.james.
- December 6, 2019 at 4:33 pm #5238
I don’t want to restart but the power cut is not up to me :) So I wanted to save the telnet changes.
December 6, 2019 at 8:42 pm #5243Just to keep this thread alive 😁
I decided to do a little experiment today, I never seen how perform old eci modem on fastpatch, when I connect it I couldn’t believe…
Asus sync with max 75500 and actual data rate is 74364, where eci sync with max speed of 78500 actual data rate was 78100, booth on fastpatch…
Beee asus, fuuuu 😂😂
Looks like asus perform better only on interleave, on fastpatch stayed behind old eci with chaos calmer on board 😜
Just for reference I’m connected to eci cabinet.
December 6, 2019 at 8:58 pm #5245Thanks for that, As you are on ECI cab, does G.inp work yet?
December 6, 2019 at 9:02 pm #5246No problem, unfortunately g.inp not working yet on eci. I tried to use eci as modem only and asus dsl-ac88u as router with login to ppoe session but for some reason asus don’t want to cooperate, it was working perfectly on rt-ac68u but dsl-ac88u just didn’t connect. Any ideas? 🤔
December 6, 2019 at 9:10 pm #5247Is eci with chaos calmer in bridge mode ?
December 6, 2019 at 9:11 pm #5248Yes, it is, and I put login details and all ppoe settings exactly the same as in rt-ac68u, and it didn’t work…
December 6, 2019 at 9:51 pm #5255If under WAN > Internet Connection > Transfer Mode / Ethernet WAN (or WAN) I forget which it is for the DSL-AC88U
And set WAN Connection Type is PPPoE and on the bottom of that page you enter ISP Account username and password details
If you have done this, then this does sound like another feature on the DSL-AC88U that does not work ?
December 6, 2019 at 10:02 pm #5256Yes, connection through wan, then user name and password in next step, press connect after about 30 seconds pop up message that limit was exceeded and option for try again or wifi settings, so I skipped auto config and go to wan settings, set all exactly same as on rt-ac68u and it didn’t connect. Plugged back rt-ac68u to eci and all good.
Not sure if this have something to do with switch between internet from dsl port and wan, so going this route probably as you said another fw issue.
December 6, 2019 at 10:29 pm #5258Not heard of others with this issue, so will be interesting to hear if others have similar problems
December 6, 2019 at 10:36 pm #5259Does anyone else tried to connect asus dsl-ac88u as router only? 🤔
December 7, 2019 at 1:05 pm #5263Yes I am using it as a router only through the wan
Any idea when the next firmware update will be available ?
December 7, 2019 at 1:25 pm #5266December 7, 2019 at 3:03 pm #5267December 7, 2019 at 8:17 pm #5270I am using ISP provided modem, Huawei HG630 V2 which does the ppoe part ? I am not sure how to do ppoe from Asus via another modem ?
December 7, 2019 at 8:25 pm #5271If you use modem in bridge mode you need to use ppoe authentication through asus by typing in asus type of connection (ppoe), username and password. If your asus is set to get ip automatically you are connected to modem-router?
I start thinking if I didn’t mess up something with fw on eci (updated dsl fw only) but as far I remember it worked before I switched to dsl-ac88u… Maybe it just died? 🤔
Will flash from scratch chaos calmer and will go from there…
