› UKTH forums › 🛜 Wireless Routers & Modems › ASUS & Wireless › ASUS – DSL-AC88U / DSL-AC3100 Firmwares (beta's) etc. Looks like a new Beta Release for the DSL-AC88U is available, this version has Telnet enabled and improved 2.4GHz wifi (I believe). DSL-AC88U_v9.10.06_build581_debug.w.zip https://www.asuswebstorage.com/navigate/s/604D61534F2541D1B3CE1CC031A697E4Y   UK Sentinel In a completely...
Viewing 15 posts - 1,366 through 1,380 (of 1,439 total)
  • #18755
    ChrisChris
    • Replies 26
    I replied to your email, but just wanted to say thanks again. I have Telnet access now via powershell/cmd.
    I have heard there is limited support for dslstats.exe to work with this, I’ve managed to gain access with it but it just reports the basic info and repeats an error message stating “” is not a valid integer – admin and password are blank and cmd is custom set to bcm_xdslctl.
    Cheers.
    Bt G.Fast | Draytek Vigor 2766AC | RT-AX82u
    i9 10900k @ 5.3GHz | 32GB DDR4 4000MHz CL16 | Aorus Xtreme 3080ti 2100MHz | LG 3840x1600 175Hz | X34a 3440x1440 100Hz |
    http://www.3dmark.com/spy/23655081
    #18756
    • Replies 8,707
    No problem,what are you trying to achieve with dslstats.exe ?
    The DSL-AC88U as you may not know, was manufactured and coded by a company that ASUS outsourced this to, hence why such a poor product and normal way of working are non-standard .
    #18758
    ChrisChris
    • Replies 26
    I didn’t know it was outsourced, I just knew it was a quickly pushed aside product like it never even existed lol.
    Basically I’m having a lot of issues, while BT are saying there’s no fault (of course)  using the wholesale speed checker I’ve gone from estimated 220 down (clean) to estimated 160 down (clean) and I only checked this from having several dropouts per day (Tried using the homehub and the DSL-AC88U, changed cables, using the test socket, checked my outside line within the boundary of my property and its fine).
    I’m getting packet loss, I’m getting buffering and just a lot of drops and issues over the last three months, generic line issues and noise. I’m trying to find the cause and rule out things before last resort an openreach engineer comes out and finds the reason “just inside your property boundary unfortunately” and charges me again.
    When I had this installed the engineer was seeing 330/50 but did inform me it will fluctuate during the initial settle in period. It settled around 220mb which i was happy with, but I’m assuming more and more people are connected to the cabinet (or the degraded copper line is finally on its arse).
    If I go to BT as a new customer they wont even offer me the G.fast package to this address any more, so I’m sure its something on their end.
    I was just hoping if there was a way to monitor my connection say over 24 hours – with just the DSL-AC88U and my pc connected hardwired as always, to see whats happening.
    #18760
    • Replies 8,707
    Screen dump your DSL stats/log page if you can so we can see whats going on
    #18761
    • Replies 1,035
    I would test with different modem and hopefully have no problems anymore.
    #18762
    ChrisChris
    • Replies 26
    Will do, just had a Random full reset of the AC88U though, just beta things.
    I’ve tried the original BT homehub, I don’t have easy access to another Modem (G.fast line).
    #18763
    ChrisChris
    • Replies 26
    Here’s the direct page from the Asus itself, but as I said I’ve just had a full reset randomly so its basically showing nothing. Eventually CRC and the occasional ES error on the down starts coming through, the data rate drops, the TCM on the upload changes from “ON” to numbers.
    The system log continuously shows the drops and restarts but the physical system uptime doesnt drop so its not like a power drop, the dsl uptime restarts every time it drops.
    Is anybody else using this for BT G.fast? I’ve tried multiple DSL settings, the G.INP. G.Vectoring profiles etc and getting the same issue with all – BT could not give me the 100% correct information to use apart from the pppoe login info which ofc already know, and Openreach wont disclose anything to me just BT as im their customer not openreachs, the usual.
    EDIT: 2nd picture – another drop, as shown in the time and the rates starting to lower with the errors coming in. Heavily believing its out of my control.
    EDIT: 3rd drop 3rd pic lol.
    #18769
    • Replies 8,707
    Your DSL attenuation is a tad high to comfortable support G.fast. I was looking at G.fast back in the day and my attention is 18dB (VDSL) and the BT wholesale Line checker said G.fast was not supported. Others where whom where closer to cab.
    G,fast suffers greatly with REIN and SHINE issues  as it operates at much higher frequencies than say VDSL so is more prone to electrical interference.
    Have you had G.fast long and is/was the BT supplied Hub more stable ?
    Many variables issue could be including high resistance fault etc.
    #18770
    ChrisChris
    • Replies 26
    I was also concerned about the line attenuation, but was told “it was fine” several threads of g.fast users on the bt forums and elsewhere have posted similar numbers.
    Initially I was offered a choice between 160/30 and 330/50 but was estimated 220+ so it made sense for me to pick the higher package. When the engineer came he was happy with the line and said I should get possibly 250+ but it settled at 220 ish. The wholesale checker is currently down at the minute.
    The line has been stable since I’ve had it tbh only these last 3 months or so it’s having these problems. And yeah when using the home hub, I’m getting the stats and same drops. Can’t wrap my head around it other than it being an external issue. Note pic 2, the checker said 220 clean a few days ago then changed to this.
    my contract is up shortly and they want to increase pricing and putting me on a lower speed. They’re really pushing it.
    #18774
    • Replies 8,707
    When BT Openreach Engineer visited, did he/she comment on your internal DSL wiring?
    TBH, most of the time issues are beyond your mastersocket and usually dry joints / external DSL cable etc.
    Have you tried the quite line test to see if there is any noise on the line ?
    #18776
    ChrisChris
    • Replies 26
    yeah when it was installed he actually replaced the master socket and clipped the wire outside the house, joined a new portion of cable (covered in some black kind of sealed box) and fed a new wire into the house for the socket.
    Something I have noticed is the wire to the telephone pole from my house is very droopy, Whilst all others connected to the pole going to other houses are taut. Im not sure if it’s always been like this or since we had those terrible winds. Either way BT are saying there’s no line fault and the test socket noise was fine when I checked also.
    Could it be possible the cabinet is suddenly experiencing a lot of new connections / bandwidth use with a lot of people working from home lately, using voip network phones, streaming etc? I was told “it was first come first serve and limited availability” when I first signed for g.fast but I thought it was just sales jargon. I have a cabinet 100m away as the crow flies, but the cabinet im being served by now is showing 1km away on the kitz site. (Which would make that like attenuation make sense?)
    Using other houses in the street on the availability checker shows 80/20 packages only. I can’t wait for FTTP
    #18779
    • Replies 8,707
    1 K is what I estimated distance also, hence the concern regarding high attenuation,
    As you said, it was OK, now not and even with BT HH, is still having issues etc ? could be a dry joint, damaged line card etc.
    BT Openreach engineer required and just make sure if they visit, the HH is plugged in and it is a windy day
    #18781
    ChrisChris
    • Replies 26
    Yeah I was thinking that’s going to have to be the case. Is it possible to reset DLM without openreach yet? I remember a while ago hearing they were looking into letting providers do it from their end without having to get somebody out to the cab.
    Somebody hit a power cable near by last year and it lead to rolling blackouts which led DLM to go wild on my line and lock me down to a low band when it was seeing the constant line drops until i requested a reset and it instantly went back to 220+
    I’m mentioning this because a few weeks ago the substation around the corner blew up and caused the same problem, electric on for 10 minutes. Off for an hour. On. Off. On. off. Wondering if this has screwed something, the cabs usually have battery back ups though I believe. And my hardware is surge protected plus the home hub wasn’t plugged in at the time which should eliminate hardware issue as it’s still having the issue when switching back to the HH.
    #18782
    • Replies 8,707
    ISP’s can put a request in to get DLM reset, but I believe it has to be justified i.e. ISP gives case history of why DSL synch rate is below par etc.
    Little point in you case until underlying issue is resolved, if Openreach engineer visits property and finds fault, they can then also perform this reset action themselves.
    #18783
    ChrisChris
    • Replies 26
    Yeah I’ve had a couple done before. We even went to the cabinet together which is what’s confusing me as because it was the cabinet 100m away from the house that time.
    Thanks for all your help and patience by the way. It’s difficult to find any one in the know, it’s beyond the scope of bt customer service and openreach have got back to me with a generic “we won’t deal with you call your isp” as I was expecting.
    I can’t even get the answer from them if I should be using SRA, Bitswap, G.INP or G.Vectoring and the bt forums dont help much either.
