October 2, 2018 at 11:10 am in reply to: ASUS – DSL-AC88U / DSL-AC3100 Firmwares (beta's) etc. Looks like a new Beta Release for the DSL-AC88U is available, this version has Telnet enabled and improved 2.4GHz wifi (I believe). DSL-AC88U_v9.10.06_build581_debug.w.zip https://www.asuswebstorage.com/navigate/s/604D61534F2541D1B3CE1CC031A697E4Y UK Sentinel In a completely... #979
I have received the same build from ASUS. I have started now the new test but without reset the settings because Iβm not at home to reinitialize all the parameters with the correct values. But I hope that this is not a problem.
Date Time Used % Free ---------------------------------- 2018-10-02 11:45 179MB (39%) 279MB
Good job ;)
The router of my ISP is the Comtrend AR 5307U, for me is more important the upload than download I prefer 2.5mb of upload and 10mb of download than 25 MB of download and 2 of upload. Thanks.
The Comtrend AR5307U alsoΒ has a MediaTeK chipset, so looks like in your part of the world, for highest upload synch speed (Annex M) , MediaTeK chipset suits your needs best.
I personnaly use Lantiq based DSL chipset, but they, like Broadcom, will not synch as at a higher rate compared to MediaTeK, but are very stable.
Looks like DSL-AC56 is a wise upgrade, for you
October 2, 2018 at 10:40 am in reply to: ASUS – DSL-AC88U / DSL-AC3100 Firmwares (beta's) etc. Looks like a new Beta Release for the DSL-AC88U is available, this version has Telnet enabled and improved 2.4GHz wifi (I believe). DSL-AC88U_v9.10.06_build581_debug.w.zip https://www.asuswebstorage.com/navigate/s/604D61534F2541D1B3CE1CC031A697E4Y UK Sentinel In a completely... #976ASUS have given me a copy of there latest DSL-AC88U firmware with memory leak fix, see below and please be aware, this is a beta, so read ASUS DSL Beta Firmware Policy, top of ASUS Forum and I am happy to pass back comments to ASUS if this helps?
We have found root cause of memory leak issue, but not sure whether this is the only issue at the moment. This version is based on Build578 codebase, with Broadcom Patch5/ all WiFi patches adopted and with this memory leak issue fixed, should be optimal version currently. Feel free to share on your forums.Β
DSL-AC88U_v9.10.06_build585.zip
https://www.asuswebstorage.com/navigate/s/23991F8488394DAF92CBE25B97A5AB88Y
Alternate link is as follows.
https://www.asuswebstorage.com/navigate/s/8E6759046D13459BA0A9FCE3508A8DEC4Edit: DSL-AC3100_v9.10.06_build585.zip
https://www.asuswebstorage.com/navigate/s/9443A5F69A7A405AAFEF7993A892051BY
Factory reset Advised after flashing firmware
I assume the download Synch speed increased with Annex B, is Upload Synch speed being higher more important than download?
Let us know what name of ISP Modem name is, so I can check what DSL chipset is has?
October 1, 2018 at 7:32 pm in reply to: Asus RT-AC86u Just bought one from Amazon for Β£160.93p #970Yeah was looking at the general log.
need to upgrade to ASUSWRT-Merlin to get that level of Log Audit ;)
October 1, 2018 at 7:14 pm in reply to: Asus RT-AC86u Just bought one from Amazon for Β£160.93p #967October 1, 2018 at 7:06 pm in reply to: Asus RT-AC86u Just bought one from Amazon for Β£160.93p #965Was your RT-AC66u running RMerlin firmware ? I assume you are running upto date firmware for your RT-AC86U? (Version 3.0.0.4.384.32799 )
I contacted my ISP many times and they say that my line is OK. When I mention that I have an ASUS modem, they reply that they canΒ΄t guarantee functionality with any other modem than ISPΒ΄s supplied one. Then they suggest me to try their modem. The problem is that I donΒ΄t have it. Or better to say I have one, but not very modern (It doesnΒ΄t support G.INP nor G.Vector at all.) Anyway thanks for your help. I will keep trying to find other solution.
Maybe a thought to send ASUS a feedback form from Routers User Interface (GUI) and see if they can add any value, mention you have spoken about it to ‘UK Sentinel’ and they may (no guarantee) be able to assist or fix technical issue with router?
Worth a try?
October 1, 2018 at 3:51 pm in reply to: ASUS – DSL-AC88U / DSL-AC3100 Firmwares (beta's) etc. Looks like a new Beta Release for the DSL-AC88U is available, this version has Telnet enabled and improved 2.4GHz wifi (I believe). DSL-AC88U_v9.10.06_build581_debug.w.zip https://www.asuswebstorage.com/navigate/s/604D61534F2541D1B3CE1CC031A697E4Y UK Sentinel In a completely... #959Maybe worth a call to see if you have a line fault, I noticed – ‘No response to 10 echo-requests’ –Β which would suggest line fault ?
FYI –Β if the gateway is failing to respond to echo requests, hence the router will send these requests until the gateway/exchange replies, or disconnect connection,Β This is something you may have to investigate with your ISP?
When you do speak with them, mention your using a DSL-AC55U?
Both the DSl-AC52 and DSL-AC56U have the same MediaTeK DSL chipset, but the DSL-AC56U does have more RAM and is a good little unit.
Was you given a modem with your ISP service, what does the stats on this read?
Alas the Broadcom 63138 DSL chipset for ADSL is not ideal, maybe worth looking at an older Broadcom based modem/router?
For testing, try Annex A, just out of interest, I know in theory, Annex M should have more Upload Synch speed, but worth testing, ?
what firmware you on, latest beta isΒ DSL ASUSWRT firmware v9.1.2.3_576-gebbda6c
When you had G.INP enabled, did the DSL logs give any clues as to why connection could not be made?
Latest Beta Firmwares for DSL-AC51 to DSL-N66U incl. DSL-AC750
September 30, 2018 at 5:41 pm in reply to: ASUS – DSL-AC88U / DSL-AC3100 Firmwares (beta's) etc. Looks like a new Beta Release for the DSL-AC88U is available, this version has Telnet enabled and improved 2.4GHz wifi (I believe). DSL-AC88U_v9.10.06_build581_debug.w.zip https://www.asuswebstorage.com/navigate/s/604D61534F2541D1B3CE1CC031A697E4Y UK Sentinel In a completely... #938β Revert to build 540 β WiFi 2.4GHz, 5GHz, Guest (no MAC Filter) β DDNS β DHCP da 192.168.1.50 a 192.168.1.199 β Port Forwarding (10 rules) β AI Protection off (default) β Firewall ON (after a switch to off and after a restore to on, otherwise I was not able to navigate on some sites, for example the Italian forum related the router).
Date Time Used % Free ---------------------------------- 2018-09-28 22:30 168MB (37%) 289MB 2018-09-29 07:20 170MB (37%) 288MB 2018-09-29 12:05 171MB (37%) 287MB 2018-09-29 15:30 171MB (37%) 287MB 2018-09-29 18:00 171MB (37%) 287MB 2018-09-29 20:30 171MB (37%) 287MB 2018-09-29 22:40 171MB (37%) 287MB 2018-09-30 09:00 171MB (37%) 286MB 2018-09-30 12:00 172MB (38%) 285MB 2018-09-30 14:00 173MB (38%) 284MB 2018-09-30 18:30 173MB (38%) 284MB
Hi @gigios, this is still showing no increase in memory usage by the DSL-AC88U running Beta 540 firmware. I think you have proved very well beta540 is a good point to allow ASUS to start new firmware development. I am happy for you to stop and will tell ASUS of your good work and results.
Thnk you for your kind help ;)
September 30, 2018 at 5:30 pm in reply to: FRITZ!Box 3490 – Official Thread Looks like Fritz!Box 3490 has a new firmware 7.01 release that support Mesh Improvements Release date: 01.10.2018 Changelog: https://en.avm.de/nc/service/downloads/download/show/YToyOntzOjc6ImRpc3BsYXkiO3M6MTQ6IkZSSVRaIUJveCAzNDkwIjtzOjM6InVybCI7czo3MjoiaHR0cDovL2Rvd25sb2FkLmF2bS5kZS9mcml0emJveC9mcml0emJveC0zNDkwL290aGVyL2ZyaXR6Lm9zL2luZm9fZW4udHh0Ijt9/ The update file “FRITZ.Box_3490.140.xx.xx.image” on http://ftp.avm.de contains the latest FRITZ!OS (Firmware)... #936Β£100 bargain for FTTP, the survey as you may or may not know I assume will be dependant on how far you are from the DSLAM, let us know how it goes and if they want to use you as a trial, you might get a better deal ;)
I am also with PlusNet VDSL, so will be interesting to see how yours progresses?
Is it possible to tweak SNR manually even on the DSL-AC88U? I thought you canΒ΄t do it on Broadcom chipset.
It is on my DSL-AC88U, ASUS have always said, for ADSL, SNR Tweaking is available, for VDSL, it is not. unsure about Annex M, but assume it still applies like ADSL
Have a look under Administration > DSL Settings > Stability Adjustment (ADSL) ;)
