Asus RT-AX88U / Pro – Firmware Updates Thread ============================ Router Model – Asus RT-AX88U Firmware Version – 3.0.0.4.384.7756 Firmware Release Date – 2019/11/25 ============================ Changelog – – Enhanced the Wi-Fi 6 performance with Apple® iPhone11, Samsung® S10. –…
UKTH forums 🛜 Wireless Routers & Modems ASUS & Wireless Asus RT-AX88U / Pro – Firmware Updates Thread ============================ Router Model – Asus RT-AX88U Firmware Version – 3.0.0.4.384.7756 Firmware Release Date – 2019/11/25 ============================ Changelog – – Enhanced the Wi-Fi 6 performance with Apple® iPhone11, Samsung® S10. –...
Viewing 15 posts - 106 through 120 (of 139 total)
  • #8052
    AvatarMrk26
    • Replies 465
    Unfortunately I had similar issue when rt-ax88u came to my house and I have to update wifi drivers on all laptops and pc in my house. One thing you can try is to create guest network for 2.4Ghz and see if that will work.
    • Replies 8,460
    Also look under Advanced Settings > Wireless > General is an option for ‘Wireless Mode’ Select N for 2.4 GHz or 5 GHz and create new SSID just for that legacy laptop.
    I think as @Mrk26 said, Guest option with Wireless Mode set to N should work if that option is available via guest wifi, but I think guest wifi does not allow access to local printers etc, only internet access.
    #8054
    Avatarbwj
    • Replies 13
    OK thanks for the tips
    The laptop was blocked from acessing wifi printers etc anyway so guest network sounds like the way to go for simple internet access.
    AvatarMrk26
    • Replies 465
    New Fw available here:
    Version 3.0.0.4.384.9559
    2020/07/28
    69.39 MBytes
    ASUS RT-AX88U Firmware version 3.0.0.4.384.9559
    – Fix CallStranger vulnerability (CVE-2020-12695)
    – Improved system stability.
    So far so good, no issues after upgrade.
    • Replies 8,460
    Hi @Mrk26 – thanks for update news, some are saying there maybe issues with ISP’s DHCP and  some Wireless N clients are struggling with AX radios enabled ?
    Let us know how yours RT-AX88U works out with this latest firmware if you have not switched to ASUSWRT-Merlin already ;-)
    #8772
    AvatarMrk26
    • Replies 465
    I have connected several different devices and no issues at all, nice and stable like previous official build.
    I used Merlin fw on mine a while ago and once switched to previous official fw didn’t have a chance to messing around. Can’t really afford any possibly unstable builds especially where I still working from home so stable broadband connection is a key.
    • Replies 8,460
    stable broadband is very important, thanks for letting us know how good the new ASUS RT-AX88U firmware build is, good to know the build is good
    #9090
    AvatarMrk26
    • Replies 465
    New fw available here
    Version 3.0.0.4.384.9566
    Date 2020/08/03
    Size 69.4 MBytes
    ASUS RT-AX88U Firmware version 3.0.0.4.384.9566
    – Fixed static IP WAN connection issues.
    – Fixed wan link aggregation stability issues.
    MD5: 26434f89415f68d9dec463bf4c598705
    Didn’t have any issues with previous fw or this one. Nice and smooth after update.
    • Replies 8,460
    With these recent firmware’s for the RT-AX88U that seem to be working well,  you must be enjoying all the extra free time you have nowadays
    #9194
    AvatarMrk26
    • Replies 465
    I think we all appreciate peace of mind from time to time
    It’s nice to see that this router is supported properly by Asus.
    • Replies 8,460
    I read this on SNBForums the other day, almost got worried I did. (RMerlin a little unhappy with ASUS (RT) models development/release cycles)
    https://www.snbforums.com/threads/release-asuswrt-merlin-384-19-is-now-available.65801/page-10#post-611807
    #9214
    AvatarMrk26
    • Replies 465
    I read something similar in different topic where Merlin was upset with the way how Asus upgrade fw on routers, but that is the only problem for Merlin because he tried hard to push updates to older routers which Asus slowly left behind.
    • Replies 8,460
    I hope ASUS are working hard to keep @RMerlin onside with there newer 386 GPL releases ,
    #20653
    • Replies 8,460
    New firmware release for ASUS RT-AX88U Firmware version
    ASUS RT-AX88U Firmware version 3.0.0.4.388.20499
    Version: 3.0.0.4.388.20499
    Release date:  2022/08/25
    • Supported WireGuard VPN server and client.
    • Supported VPN fusion. It can easily achieve VPN connection to network devices like Smart TV, Game consoles and without installing the VPN client software.
    • Supported new devices connection notification.
    • Supported connection diagnostic on the ASUS router app.
    • Supported Instant Guard 2.0 which helps easily invite family or friends to join the VPN connection.
    • Upgraded parental control and added reward, new scheduler for flexible setting
    • Fixed USB icon issue in port status.
    https://dlcdnets.asus.com/pub/ASUS/wireless/RT-AX88U/FW_RT_AX88U_300438820499.zip
    #20654
    • Replies 8,460
    Looks like this new firmware release for the ASUS RT-AX88U supports WireGuard VPN Server and Client
    WireGuard VPN Server and Client.
